1 - 6 of 6 Posts
Welcome,
If it's 4x4 there's a silver switch lever (4WD lock) in the console by the cup holder and parking brake. If it's 2wd there's no switch lever.
92739
You can also look under the vehicle and see if there's a drive shaft to the rear wheels and a rear differential.
So it doesn't use 4wheel at all like part time 4wd...
If you have the switch lever in the console then you have 4wd which works like the video above.
If you don't have the switch lever, then you don't have 4x4, only 2WD/FWD.
Yep, another switch I may have to replace in order to get that 4wd! light to stay off after traveling over 1 mile. I did pop that 4wd lock out & one of the pins on the pcb is really corroded. Just a thought for $60...
1 - 6 of 6 Posts
