Frozen Windshield Fluid Help
5.9K views 14 replies 9 participants last post by  jack.allwardt
Hello Everyone,
So I currently purchased a 2015 Jeep Patriot and I believe the dealer put windshield wiper fluid that isn't compatible with the cold.
This week, the D.C area has gotten a cold front with some snow.
The fluid appears to be frozen and isn't flowing through the hoses.
Any recommendations to defreeze and empty out the wiper fluid?
Thanks in advance!
I'd love to add Isopropyl but its corrosive to my Benz aluminum windshield wiper lines.
Mine has been frozen the last couple days too. Most likely your fluid has lost its potency over time.
Step 1: Thaw it out, as in park it in the sun (even at 0 F. the sun will probably do the job) or get it into a garage. My unheated garage warms up into the 20s with a couple warm vehicles parked inside. Unless you're running straight water in your w/s/w, getting even close to 32F should get things thawed.
Step 2: I'm with festerw above. However, alcohol will keep things from freezing, but won't thaw anything until it gets into the lines.
I can't imagine its going to corrode your lines. W/s/w fluid has alcohol in it normally. I'd be more concerned about it affecting the paint. Fortunately alcohol evaporates quickly.
Mine was frozen this morning. If you're driving, the heat from the engine will unfreeze the little hoses (and the nozzles) if not right away then after you stop.
I'm guilty of being lazy and just adding water in the summertime, usually I add a cheap version of window cleaner with the water.
Mine started working within 20 minutes after I started the car today.
Funny thing. Mine froze up on Sunday. I first noticed the rear w/s/w wasn't working, then discovered the front wasn't either. After being parked in the sun while I was in church, I tried the rear again and the fronts dribbled a little spray, even though I was pressing the rear. :confused: Once it was thoroughly thawed it worked fine. I never put water in mine; usually the dealer tops it off when they do an oil change. Maybe they aren't using the best stuff?
No my Benz uses aluminum lines hence the corrosion, my Jeep uses plastic lines.
I may dump a bottle of alcohol in the Jeep tho just for good measure :)
When I lived in CA, they weren't allowed to sell windshield washer fluid with anti-freeze--it's the VOCs, you know. And how many middle-aged folks looked at what they had, exclaimed that their fluid protected to +32, and isn't that enough? Yeah, this engineer said, sure, just like tap water---Now, here in WA state, no problem getting -40 washer fluid! Which I will use year around!
Reactions: RossoRacer
VOCs in w/s/w fluid? What if you live in the mountains? It must get cold in some places in California. Of was that just a city or county ordinance?
Then again my first car (1960 Ford) wasn't even equipped with a w/s/washer; and yes, it was a problem in winter driving. If I ran the wipers long enough I could usually rub most of the scum off. Either that or I'd get out and throw some snow on the windshield. Having a w/s/w is much handier.
