Battery went caput
4.2K views 28 replies 9 participants last post by  rcguymike
Went to leave Cabelas in Minneapolis and the car wouldn't even indicate it had power. Not even my LED lights would turn on. Geico roadside assistance is coming to try to jump-start it again, and then tow me to a battery place down the road. I get a 5% discount as it's a partnering firestone store, so might as well get a nice deep cycle or whatever I can get fit that will work.
Already tried jump starting it and let it run for a bit but it would die within 5 seconds of disconnecting. Hopefully it's just the battery and not the alternator too.
sounds like your alternator is gone if it's dying while running. you can actually run the vehicle without a battery so long as you get a jump every time. test the alternator by disconnecting the positive from the battery while it's running. if it dies, your alt is toast.
#4 · (Edited)
And it jump-started when the tow truck guy came and it ran fine. Drove over to the tires plus place and it turned off and back on fine. Checked the battery terminals and they are tight, $28 for diagnostic. Wonder if it's related to the new engine wiring harness and new computer I got... Almost wish I could get this declared a lemon and get a wrangler instead...
Yup, that was the plan, something similar to what you have but maybe not quite as expensive.
After writing a whole big thing and now re reading everything... sounds like bad connection at alternator. Just check around for anything out of the ordinary
Ding ding ding, we have a winner. According to the shop the alternator is on its way out as well as the negative terminal had some corrosion that was preventing a solid reliable connection. They cleaned that and it's starting and running fine now, have an appointment at the Jeep dealer to check it all out and confirm Wednesday.
What are some good options for alternators if it's bad. The service guy said it's probably not covered under warranty as I'm at almost 48000 miles and it would only be covered under the 3 yr/36k mi. The original people that looked at it wanted $380 for a re-manufactured 115 amp alternator(the only 140 amp one they had access to was from NAPA and they suggested not getting that one) plus $140 for the install, but I think I heard of some people on here getting custom alternators for around that price or close. I'm willing to do the install myself.
Thanks guys!
Was hoping to have this battery last until winter, which it looks like it might. Turns out one of the 3 diodes in the rectifier is shorted and one of the battery terminals had a bit of corrosion on a connection. I think the alternator is covered under warranty so I'm attempting to drive it back to Michigan. 4 more hours to go with the alternator only putting out 13.7 volts.
Still no power at the OBD2 port...?
Why would someone not suggest getting the 140amp. If the cost is close between the 2 may as well get the bigger one. I'd like a bigger than 140a alternator but with my large battery the 140 suits me just fine
I just replaced my alternator, and I went with a 115-amp unit (tight budget). Does the 140-amp alternator put more of a load on the engine during normal operation, or is it simply capable of turning out more amps when they're required?
I haven't noticed any issues due to extra load on the engine because of the alternator. It is nice having that extra 20A. For install I recommend following Todde's thread and moving the water pump to the outside of the vehicle. But sadly realized last night after 15-20mins of cranking the subs, the batteries are drained and it starts to hit the alternator.
I think you are getting carried away in how much power you lose through your alternator...........its really not noticeable, just get a K&N and regain the 6HP you've lost elsewhere =)
