Battery Light Always Comes On
1.9K views 2 replies 2 participants last post by  codyrh
I'm hoping I can get some sort of solution to fix this problem I've been having now for months with my 2013 Patriot, it now has 116k miles and now for the past few months my battery light came on. Had the system tested and sure enough my alternator was failing, so I replaced it with a re-manufactured alternator. Well I still had charging problems and decided to put a new battery in it and charging problems still came up along with the battery light popping on, so I had the system tested a second time and concluded the alternator was bad so I bought a brand new one and replaced. Also I put a brand new serpentine belt on it and all the pullys and tensional are good still. I earlier today checked out my starter since I had put a new starter in a couple months ago and noticed I forgot a ground wire that was unhooked so I fixed that today thinking that could have been the issue. Took it for a drive and my battery light still comes on and even I drive it for too long the car will die. I double checked all my wiring going to the alternator and its all hooked up and not an issue. I also replaced the PCM thinking it could be the cause of the issue but its still has some sort of charge issue I can not seem to figure out. Would anyone on here have any ideas on this or have had the same type of issue? Feedback would be great-full
-Cody
