Aftermarket Radio Installation Information. Quick and easy.
61K views 18 replies 14 participants last post by  avatarandrew
All too often I see people either limiting themselves to the stock unit simply because they're intimidated by the thought of installing an aftermarket radio on their own. Or.. They end up shelling out ridiculous amounts of money to have a "professional" do it for them. Using the harnesses available today, you can revert back to the stock radio whenever you please because no wire cutting is needed. If you can twist wires together, use tape and/or wire nuts and turn a screwdriver, this is NOT "out of your league"!
If you're willing to do a small amount of research about your specific vehicle such as:
- The obvious.. Year of Patriot
- If you have/want to retain steering wheel controls
- Do you have a "Premium Sound" and/or Nav package?
You need to know this information so you can buy the correct harness/adapter(s) for your specific application.
I've used PAC for most of the wiring related adapters and it's a breeze.
http://www.pac-audio.com/
Just enter your vehicle information and they'll show you what's available for your 'Riot.
Next, you'll need to figure out which DIN size radio you plan to install so you know what dash kit is for you. Pretty simple here.. Most commonly either a single DIN or double DIN. I've had both single and double DIN's in my 'Riot and the only difference was the metal bracket in the dash you'll need to remove if using a double DIN unit. No biggie.
I found the dash kit, PAC harness and antenna adapter for my vehicle on eBay for $80 total.
Here's a quick video I made to show how to remove the bezel/radio in my 2011.
Hope this helps those who are interested in exploring the lovely world of aftermarket audio. Enjoy!
Reactions: vauxfox
If I were actually wiring anything I would take the precaution, but it was simply removing and poppin it back in. Even when I do wire em up, I usually don't disconnect the battery. Just wire the harness to the radio without the harness being plugged in. Same concept. That way no stripped wires are dangling around while hot.
dB-SPL
You need to forewarn folks that most aftermarket head units do not fit the Patriot's enclosure. I had to go through a few before I found one that fit, they were too big for the dash opening. I ended up with the Jensen that I have as that was the one that fit.
Please dont use vinyl tape when wiring a radio. use bell-caps and crimp the wires together. It gets really hot behind the radio, and not too long ago we just had 15 cars burn down at an apartment because someone used electrical tape on their stereo install. The adhesive gets gooey and the tape slips off, leaving the wires exposed.
But thanks for the instructions! We get a LOT of repeated questions about radio installs.
X2, If you have the skills and tools solder and heat-shrink are even better, that is how I've done all my stereo installs and never had an issue, but yes at the very least use crimp connectors, and then use tape over the crimps if you want, but never just tape. If you do use any tape (again only in addition to something else), spend the money (not much, about $5) on scotch super 33+ or super 88+, the cheap "made in China" electrical tape is all crap and won't last long, especially if exposed to high heat.
I am having a bear of a time finding a radio wiring harness for my BASIC 2009 Jeep Patriot.
It DOES NOT have controls on the steering wheel.
It DOES NOT have any add-one like navigation or the like.
It is just a simple AM/FM CD radio with an opening for external input (3mm) Jack.
Any suggestions out there as all I am finding are wiring harnesses at Crutchfield and the above for $60- $160+.
Thank you in advance.
This what u need for a basic install, I used this on mine for the new double din stereo I installed
