4Low disables esp?
2.6K views 22 replies 8 participants last post by  rcguymike
Does the low range gear automatically disable esp? Is it automatically in partial or full off when it does? Last time I was off roading I seemed to be able to get more wheel slip when I manually turned esp full off. What is the difference between full off and partial off esp?
I don't understand the difference between Partial Off and Full Off on a Patriot with FD1. I think Full Off disables ERM ?? Roll Mitigation ?? but I never get stuck with Partial Off and Auto Stick in 1st gear seems just great without the engine slow down you get with ESP On. The link below shows a very lame description of AWD versus 4 Wheel Drive by MSN; I guess they don't know anything about Jeeps.
http://www.msn.com/en-ca/autos/owne...utos/ownership/the-need-to-know-basics-of-all-wheel-drive/ar-AAgcHoN?li=AAggFp0
Partial raises the limits allowed for wheel spin before intervening by applying the brakes and cutting the engine power. Full off does not apply the brakes (other than BLD) and doesn't cut engine power at all.
Dixiedawg I run esp full off and run in Low without 4x4 locked all the time when offroad, only engaging the FDII mode if I get stuck.
.... and doesn't cut engine power at all.
Actually, it still can and does (even in off-road mode) due to the stability sensor under the console. Had it happen trying to go fast up a steep, off camber, muddy hill with large whoopti's in it and an 8' deep washout on the low side. Soon as I hit the bumps the traction control light started flashing and it started cutting engine power, making us lose speed and start sliding down towards the edge of the washout. :wow: Thankfully, we made it through.
The only way to shut off the ESP completely is to either pull an abs fuse, or cut power to stability module itself.
Something interesting from the manual about performance.
NOTE: For maximum off-road performance, premium
fuel is recommended. While the vehicle will operate on
regular fuel when in L Off-Road mode, the engine has
been calibrated for maximum performance using premium
fuel.
Except when all the tires get spinning at the same time, then there is little bld activation, when all the tires can spin at nearly the same speed, the BLD's don't really get in the way.
You can see/hear the BLD's kick in and bring the RPMS down until the wheels get going the same speed and then its clear sailing!
