2014 Jeep Patriot Check Engine P0036
326 views 4 replies 3 participants last post by  SwedeMike
Hello, I have a check engine light with code p0036, indicating the downstream O2 sensor issue, I replaced the O2 sensor that is connected to the cat, did not clear, I replaced the ECM and still do not clear, is what is the cable called that connects the O2 sensor to the ECM?
Thank you
P0036 apparently isn't in my copy of the 2014 service manual, but problems with the heater circuit can be caused by a bad ground connection at one of the engine bay grounds. The wires can corrode in and around the crimp where it isn't always visible.
The fix is cutting off the old eyelet, stripping the wires to good metal, and adding a new eyelet. Some have used multiple eyelets or a bus bar.
More info on the grounds here:
Thank you,,,,I will try to tackle it in the AM!
