My Jeep Patriot started over heating a couple of days ago. while checking ou tthe issue i realize none of the radiator fans ws actually turning,i checked in my relay box switch the relay around then when the A/C on one fan only start spin i switch all relays where the main relay is located testing each one by one and all seems to work because the vehilce started so i can rule out relay are bad some relay seems to have a little corrision on ends but all seems to work confirm that. The fan which is not turning on which is the one the temperatur sensor triggers i ddi a direct connection on it and works. I do not believe is the temperature sensor thats the issue also because the A?c suppose to trigger that fan too and it didn't. So where do i go from there only thing i am guesssing corroded wires at the bottom of relay box if anyone has had that issue please can you hel p me out thanks.
