Found these on CL, originally from a 2006 Wrangler. (Sorry for the huge pics)
Don't know for sure, but this might be what JeepinLG had. http://www.jeeppatriot.com/forum/showthread.php?t=8723
I wanted to mount the full set but didn't have time, so I put one on the front passenger side. Fully mounted it clears the caliper, spring perch, & pinch weld. No contact on full lock either way. No spacers were used.
Rim / Caliper Clearance
Tire / Pinch weld
Tire / Spring Perch
Rim / Strut clearance.
Not much more than 1/16" clearance here, if that. Doesn't rub, but if it does, I guess it will just "auto-clearance" itself.
Here's a few pics of the inside of the rim:
Weight-wise, when I lifted the Ravine it felt lighter compared to the stock 17" SRA. I weighed them on a cheap digital bath scale they ranged from 45 to 47 lbs, the difference probably due in part to different balancing weights.
In contrast, the stock 17" SRA weighed in at 50.5 lbs.
The GSA is discontinued and the only source of specs I found was an old Ebay ad which claims the 30x9.5R15 weighs 35 lbs. If so, that puts the rim at 11 lbs., which would be great but seems too light to me. I'm thinking more like 15-18 lb, which would make the tire similar in weight to the SRA. If anyone has better specs on this tire, please feel free to add them.
Tire / Pinch weld
Tire / Spring Perch
