If you are talking about under the Jeep onto the ground, yes.
Air conditioning not only cools the air but also takes out the humidity (water vapor condenses to water). The water droplets collect on the evaporator coil (sometimes called the cooling coil) and then falls into the drain and out onto the ground.
packof50, has it been extremely humid where you are lately? I have not experienced anything out the ordinary in the Patriot, but my old Dakota's air used to get really cold and water vapor in the cabin would condense around the vents.
