I just got my car 2 weeks ago...and the check engine light came on this morning. I checked the gas cap and it was tight...what else could it be???
cinnepa, it could be you just need to change the spark plugs. Patriots use standard copper plugs, no long life platinum's here. They should be changed every 30k miles, so you are right near the limit. Make sure who ever changes them uses die-electric grease in the rubber spark plug boots liberally.just purchased a 2007 patriot 2 days ago, 28K miles, light came on yesterday......autozone just hooked up the computer and it said cylinder 1 misfire. disgusted to say the least
With OBDII cars, the light can turn itself off if it no longer detects the fault for a certain amount of key on-off cycles. So if the cap is loose, the light won't go off right away once you tighten it back on. It may be 5 to 10 trips later.The light went away this morning, guess its related to the Gas light
