1 - 9 of 9 Posts
Rwood116
I had front wheel bearings, brakes and rotors replaced and after they were installed my abs and traction control lights came on steady. Once I started to drive it my 4wd and brake lights flashed and then came on steady. Not sure what is going on please and thank you for any information that I could use. This is on a 2014 patriot
Maybe one of your wheel speed sensors got damaged when the wheel bearings were done, or they might have put one of the front wheel bearing in backwards.
I never put a bearing in backwards, but I have destroyed a few wheel speed sensors. lol
I never had to do bearings like these ones before. I've always just replaced the whole assembly. My buddy told me that he knew how to do them so I trusted him lol. I assume the bearing has one side that is magnetic?
If it's the right bearing, yes.
Some bearings come without the magnetic ring so you have to careful to get the right one when you order.
1 - 9 of 9 Posts
