I was wondering where are the jeep Patriot drain holes in the Manuel it says that there are some on the rocker panel the door and the trunk area can someone provide pictures to show where they are located
Look for removable plugs where the arrows point:I was wondering where are the jeep Patriot drain holes in the Manuel it says that there are some on the rocker panel the door and the trunk area can someone provide pictures to show where they are located
Do this picture apply to the 2017 jeep Patriot?
Can you provide a picture?What the manual is referring to are the "drains" that allow rain water to drain. They are actually "voids" in the pinch welds along the bottom of the door, along the rocker panel and again in the rear quarters
Two places on the bottom of the door.Is there any way you can provide a picture?
Do you have a picture for the rocker panels?
Do you know what they look like?No, I don't.
Do the drain holes on the rocker panels look like vents?What the manual is referring to are the "drains" that allow rain water to drain. They are actually "voids" in the pinch welds along the bottom of the door, along the rocker panel and again in the rear quarters
that is exactly what they look like, they have a tendency to become plugged with dirt. If you open the doors and look at the bottom sides you will see what looks like drain holes. They do not usually plug up.And do the drains along the rocker panels look like vents
