Working on my '07 2.4L, 5speed, after replacing the throttle body, i got codes p2088 and p2090 i then replaced both camshaft sensors and got codes p0100 and p0013. Still won't start. Do they all need to be reset/relearned and how?
This is the relearn process I've read about but not sure if it is the correct one to use after replacing the throttle body. I've read on FB Jeep Patriot forums how people replace their own throttle body with no problems and they don't mention taking it in for a scan or relearn by the dealership.And then I came across this:
StarScan ? - ETC Relearn - Cherokee SRT8 Forum
"Tech authority states this procedure must be done when any ETC component is replaced/faults. Does anyone know what is being stored/reprogrammed in the pcm when this procedure is done? What user input is required (if any) during this process (gas pedal 0% then 100%, etc.).
Thanks."
All the voltage values for the pedal and throttle body.
Yes that kind of user input is required. "
Which sounds a lot to me like this:
http://www.jeeppatriot.com/forum/15...gine-drivetrain/42689-ecu-re-learn-procedure-without-disconnecting-battery.html
1). Turn ignition to Run, but do not start engine.
2). Wait for all idiot lights to turn off (last one will be the the throttle indicator - the two half-moons w/ a lightning bolt between them).
3). Over the course of 15 seconds, slowly depress the throttle all the way to the floor. Try not to waver or be too jerky, just a nice slow, smooth push.
4). Over the next 15 seconds, slowly let the throttle out in the same manner.
5). Allow car to sit for about an hour. (This is in the original procedure list, but i tried waiting just a minute and it worked anyway.)
6.) Start car and drive as you normally would.
If it were me I'd try the ECU relearn and see if works. Can't hurt, right?
