I figured I better start a writeup on this since it has consumed so much of my time and taken my jeep off the road for almost two weeks now.
For a couple months I have been hearing a strange noise coming from the front end of my Jeep. I installed new control arms and the RRO lift a few months ago. the ball joints in my old control arms were junk and it appears they caused me further problems. Because of the bad ball joint, my front wheel bearings wore out and were making a rubbing sound that corresponded directly to road speed. I was able to eliminate most of the drivetrain when diagnosing the problem because it did not change while driving the same speed in different gears or coasting in neutral.
Thinking "no big deal, I'll replace the bearings" I ordered a pair of replacements with the proper ABS ring and started taking things apart. While disconnecting my steering knuckles I came to the realization that I pretty much had to wreck the ball joint boots to detach them so I ordered a pair of those too. The passenger side steering knuckle came out no problem, I took the strut with it so I could keep my camber as close as possible. I am using a friend's shop in a small town nearby so I will be putting some miles on it before it gets in for an alignment, it's ok my tires are garbage anyway.
