As European emissions for diesels are tightly controlled how do they compare to US specifications?
As part of the annual test here diesels first used after 1 Aug 2002 have to pass a "fast pass" emissions test with the following procedure being carried out:
Diesel Fast Pass
Since 1 August 2002 a metered "fast pass‟ procedure has been used to help simplify
and reduce the time taken for the test, allowing vehicles with low smoke emissions to
pass the metered test after one acceleration of the engine. If, after the first
acceleration, the meter reading is at or below 1.5m-1, the vehicle will pass the meter
test.
The smoke meter will indicate to the Tester to accelerate the engine. The accelerator
pedal will be depressed quickly and continuously but not violently, to reach the full
fuel position in less than 1 second. After the release prompt is given, the Tester will
immediately release the throttle. The meter will calculate the maximum smoke
emission during the acceleration and display the result. If the smoke level reading is
at or below 1.5m-1, the vehicle has passed the metered test, and a pass result will be
displayed on the meter.
On test today my 2.0 diesel Patriot had a reading of 0.69m-1 which is low so how are US emissions measured and what is acceptable by your standards compared to Europe?
http://www.dft.gov.uk/vosa/repository/Emissions 17th Edition.pdf
Diesel Fast Pass
test.
