Who has a 5 speed manual transmission?
34K views 42 replies 32 participants last post by  jaredcalhoun41
I am thinking of getting a Patriot and I just wanted to get an idea of what the 5 speeds are like. I don't think I am going to get a chance to test drive a manual transmission in my area. All the 2010s leftover are automatics...
I don't like the things I've read about the CVT Transmissions - which is fine with me, since I was planning on getting a 5 speed anyway...
Does anyone know if if you can get a manual transmission with all the options? My dealer told me that the 5 speeds came with manual windows (not automatic windows), but I've seen 5 speeds with power windows on here...not sure why he would say that if it wasn't the case. Maybe he was getting the Patrio confused with another model...?
That dealer is on drugs...
You can get a 5 speed loaded, including Limited trim if you want. The only thing you can't get with a 5 speed is the FDII package (offroad) because you need the 19:1 crawl of the CVT. You can still get the FDI package (comes with 4x4 capability) with a manual (like mine). I've got a manual, and I've got power windows so that dealer doesn't know what he's talking about. It is true that on a lower package level power windows are optional (for all transmission options). What I would recommend is going to this link and printing out the brochure if you don't have one already. Specifically, look at the 25D, 25E and 25F packages as for determining which options you want. As I mentioned above, all the packages can come with 4x4. Good luck with your purchase! :smiley_thumbs_up::banana:
I think the packages/models are different in Canada. I think the 'Sport' models don't come with power windows/locks with the 5 speed. The North Edition does, though. I have found 2 - 5 speed, 4x4 in BC doing dealer inventory searches...they are both Sport models and I don't see anything about power windows and locks. Perhaps this is what he's talking about?
He may be thinking about the sport package, what's commonly ordered (many order the manual to avoid paying for the automatic and so won't get the power windows for the same reason), or he may also be referencing what he can bring in easily. Have you considered ordering? It takes a little while, but then you get exactly what you want. I ordered a 5 speed North Edition, loaded up except for the sunroof.
I couldn't find a single manual transmission when I ordered mine. A few weeks after it got in, they were all over the place.
Maybe this is what he's talking about (near the top of page 2). Trippy. Maybe you can buy a US edition and have it shipped?
I personnaly own a North edition fully loaded (heating seats, all power, sunroff, 9speakers BA system, etc...) with the 5 spd tranny. So maybe he was just talking about those left in stock?
Thanks, dadunkindude! That specs list you posted clearly outlines that the sport model has manual locks and windows. That's indeed what he was talking about. There isn't a North Edition 4x4 5 speed in the whole province...nuts! I don't mind ordering...but since the 2011's don't start production until Oct. 4th, that means I probably won't get my new Patriot until late November, early December. Good things happen to those who wait, I suppose... :)
#9 · (Edited)
Oooooh....they found ONE 5 speed 4x4 North Edition with power locks/windows! Black, too (which is what I wanted). ~$22,000 CAD after the $3,000 rebate! Niiiice! They'll have it in Friday/Sat, which is a drag, because I am going away for the weekend. If it's still there Monday, it could be MINE!!!! :pepper: I'd put a deposit on it to hold it till Monday if I'd actually test drove the stick before, but I haven't - so I think I'll just wing it and hope it's still there when I come back on Monday! Wish me luck!
#10 · (Edited)
I've got a 5-spd Sport, no bells, nor whistles.
The manual tranny is generally good, i haven't had a lot of problem with it. It's loud by most people's standards... my rationalle is that this is a cheap vehicle, don't expect to feel pampered. However noisy, the ride is smooth, and the shifter is notchy - some like that, some don't, i personally prefer it.
1st gear tends to be a little difficult to engage without feathering the clutch, and it runs out of breath pretty fast, but 2nd gear pulls hard, as well as 3rd and 4th - you can really appreciate the torque of the 2.4L in these gears. There's enough torque that I think 1st gear is purposely handicapped to prevent you from smoking the tires at a green light. Also, there's an appreciable amount of torque steer. At first it drove me nuts, now i don't even notice it; just takes some getting-used-to.
The clutch is firm, and pretty unforgiving. From a dead stop it's prone to stalling, if you don't keep the revs up above at least 2k RPM. Run it out to 3k, and you'll take off like a bat outta hell, whether you intended to or not. I've found that the smoothest takeoff from a dead stop requires you to be very steady on the gas, and very sparing with the clutch. Once you hit 2nd, though, you can just dump the clutch with no worries.
Don't try and hurry the tranny along, it does NOT like to shift fast - i occasionally find myself grinding 2nd if i expect to shift too quickly. Also, sometimes when i put it in Reverse, it creeps FORWARD when i let off the clutch; I just shift back to 1st, 2nd, THEN to Reverse, and it's fine after that.
And Reverse is NOT syncronized, so make sure you're at a COMPLETE stop before you shift to Reverse, or you WILL grind it.
I've heard that in some models the materials used in the 1st & 2nd gear synchros was poor quality, and there was a TSB on that... just keep it in mind. I've also heard some people claim that switching over to a higher-quality tranny fluid helps shifting IMMENSELY. I've not yet tried it, but i've only got 18k on the clock, and can't fathom changing the gearbox fluid yet.
All in all, it's no sports car, it no luxe model, and it's not a pickup from the 50's... it's somewhere between all these. :D
Most of my manual tranny experience was originally in a 94 Isuzu Rodeo. That thing was gutless, and looking back, the shifts were vague, the clutch was very forgiving (aka, slips like crazy), and there wasn't really a good gear to be in for power. But you'd get where you wanted to go... eventually.
#11 · (Edited)
I realize that for many years Chrysler says to use their ATF as the tranny fluid in their manual transaxle vehicles. What would be a higher quality tranny fluid that could make the T355 a little quieter ? Our Patriot whines a bit in 4th or 5th gear but only when coasting and never whines when under power or accelerating.
Both transmissions have pros and cons. If you are slow steady on the gas, you'll like the CVT. If you like a stomp on it, you will hate the CVT.
I like the 5 speed. I agree with Nth256.
We own the manual trans. When we were looking we came across a Patriot with leather heated seats, and all the other power options w/ a manual trans. However, it was a 2009 model and the lifetime warranty is non-transferable, so I did not want to travel the very long distance to even go drive it. If you can afford the power options and leather, just go order one. When you go to Jeep's website and "build your own" You can choose manual or auto. As was said earlier you cannot get the FDII model but everything else is up to you. Print it out and take it to some dealers or better yet copy, paste and email some dealers. See who can give you the best out the door price. A lot of dealers will tell you they have what you want in stock...probably not. Also whether you buy a car they have in stock or order one, you are gonna pay the destination charge, so may as well order one. At least then you are actually paying for the delivery of YOUR vehicle.
I have not driven a vehicle with CVT. We opted for the manual because I think they are more durable than autos. There is little to be said for CVT durability because they have not been around long. I also know that if the clutch or trans goes to **** post warranty, I can fix it. I know nothing about the CVTs. I like having control of shift changes as well.
#42 · (Edited)
Came from a 5 speed Cruiser I drove for 8 years. Its engine, transmission very similar. It would make an intermittent raddeling/grinding sound in the transmission when cold with clutch pedal out. Have noticed a few times same with Jeep. With some of the nasty reviews on the reliability of this 5 speed I hope in what you say.
I love my 5-speed. A blast to drive. The salesman is wrong. They do mostly order manuals with no options in case someone is eschewing the CVT for budgetary reasons, but mine has the power convenience group and alloy 17" rims and bigger tires. No CD changer (just a single disk), but another one in a color I didn't want had a six-CD changer as well. The local dealer had to bring mine in from a nearby state, but it was worth the short wait.
#17 · (Edited)
Another 5 speed owner. I wouldn't mess with the CVT and my wife wanted to learn stick and since she drives the most...we settled on the 5 speed. Wouldn't have it any other way.
We bought ours to keep for at least 10 years if not more. So I was concerned with how things would hold up over time & mileage. The only part you need to worry about wearing out is the clutch disc and maybe slave cylinder. With the CVT I think they grenade and then you have to replace it with a new or used unit because not a lot of trans shops rebuild them yet. Manuals are simple, cheap, and more enjoyable to drive to me than an automatic.
I have a 5-speed manual. Have always driven a stick and always will. I will shift my car when *I* want to shift, not when the vehicle computer tells it to... LOL!
Had to order mine because I couldn't find a stick on the lot or anywhere close with my color choice and options. Wouldn't change a thing.
I absolutely love it! I LOVE this JEEP!
:pepper:
Susan
2007 Limited FD1 5-spd, so heated leather seats, steering wheel audio controls, power windows/locks/keyless entry. You can still order a Limited with every option you want in a 2011 FDI.
I can baby it and never shift over 2000rpm, or redline the first 4 gears.
I test drove a Compass Rallye Limited FD1 with about 4k higher MSRP than mine, but didn't want it.
I would NOT own this vehicle with an auto. Way too low on power to have the thing constantly downshifting. My wife drives a loaded sport w 5 speed. Heated cloth, good stereo, power everything. Its a pretty fun little jeep and 26-28 mpg 4x4 is unbelievable. I think when my truck dies I'll get her a Grand and drive the Pat. Got the lifetime power train so want to keep it until it rusts into the driveway!
I want to add a little data - while I love my 5 spd Pat, I really have regretted owning it.
At 5,000 mi, I was having a big problem shifting into 2nd and 3rd. They were grinding, no matter what I did. So I took it in to my local dealership, who diagnosed it and replaced the (entire) transmission under warranty. They claimed that the problem was bad synchro calibration. So I didn't sweat it.
Then again at 20,000 mi, the same problem came back. I took it in. They blamed my driving habits as the root of the problem, right before they charged me $2600 for the install. I didn't pay for it, and apparently the warranty is conditional.
I am now at 40,000 and once again am having the same problem. My local transmission shop dropped the transmission and opened it up. It is destroyed, and now I'm trying to find another replacement.
One post and this is it? Just so we know this is for real, and not from the Toyota dirty tricks committee, where do you live and what dealer would not honor the factory 30,000 mile warranty?
You got the lemon bud, hate it for you, I bet there is more issues with cvt's than the manuals tho. You ought to come over on Challengertalk and see the nutty crap we have to go thru with issues, my challenger r/t's passenger window phantomly rolls down on me sometimes when I hit a bump, just discovered it about a month ago after owning the car for a year. The part thats worse than that is the camaro and mustang supposedly have worse problems. My Patriot also leaks in the rear hatch so thats another kick in the nuts mother mopar has gotten on me. Chrysler so they say is improving on reliability, but I bet the Pat won't before its demise shortly.
I have a 5 speed and used to have a cvt in my old compass which was garbage. I worried that my 5 speed will have the same problem, cause sometimes i get that 3rd gear grind. Also I took it in for some suspension sqeaks and was told that since my jeep had mud on it that the bent control arm was my fault, also chrysler wouldnt pay for it. srive a squeaky jeep.
