What about a white roof?
3.3K views 17 replies 13 participants last post by  UPKEV
It's getting hotter and hotter around here as spring becomes summer, and it started me thinking that a white roof might help keep the Patriot cooler in the summer. I know some vehicles like the FJ Cruiser, old Land Rovers, etc. have had white roofs that contrasted with their primary body color, and I'm wondering if anyone thought A) if this has any real benefit in terms of reducing interior temperatures, and B) if such a mod would make the Patriot look better, worse, or make no difference one way or the other.
I played around with some photos of my Patriot in the old standby "Paint" program, but since mine is Light Khaki the glare on the roof in all the photos I take make it look basically white anyway, so trying to "white out" the roof area in my photos doesn't really give me much of an indication. I did notice that on the rear because of the way the hatch is hinged, you could paint the roof white but leave the hatch body color, so the only place the white would be noticeable would be the strip just above the windshield, which I really don't think would look that bad on the lighter colored versions...not sure sure on the darker colors though.
Thoughts?
I think the heat comes from the sun hitting the interior of the car more then anything. I had a white car with a dark grey interior, and that bitch was HOT in the summer if you parked in the sun.
If you use the AC properly, you can cool the car down in about 2 minutes.
I'm with Hitzy on this one. The amount of glass area (sq. inches) is the biggest determining factor in how hot your cars interior is going to get.
But the white roof is not a bad look. (our Mini Cooper had a white roof and we loved it)
That's what I was sort of thinking on the look, but because of the way the vehicle is designed with the roof between the sides (instead of the roof sitting on top, if that makes any sense) you really can't see the roof from the side or rear, so from a style standpoint it wouldn't stand out except from the front view...I just can't decide if it would make much difference visually or not. I almost think on a khaki it would look pretty good, but then that would have the black roof rails sitting on a white roof, which might be too much contract when mixed with the different body color.
This past winter I saw my Compass with 1/2 inch of snow on the roof and the contrast to the black looked really sharp. Maybe I'll experiment with the vinyl sheeting at some point in the distant future. I'm not sure the Patriot would look good with a white top as there is no demarcation structure on the roof. (Like the seam on the roof of a Mini or the black rails on the Compass.)
I believe most of the heat comes from the sun coming into the interior via the windows/windshield, hence heating up the interior.
If you wanted to do a test you could purchase white water based paint used in preschools. Once completed you can take your Patriot to the car wash and wash the paint off !
