Warmer Weather = Better gas Mileage?
6.9K views 21 replies 17 participants last post by  darseygodwin
Now that Toronto's weather has finally warmed up, ..yesterday hit a balmy +16, I have noticed my gas mileage has improved remarkably.
Not that I have done the math, but I can just tell by how much gas I have burned driving directly to and from work via the same highway route I always take.
11K on the vehicle so the breakin period has come and gone.
Anybody else seeing this?
yes and according to wiki here is why:
[edit] Volatility
Gasoline is more volatile than diesel oil, Jet-A or kerosene, not only because of the base constituents, but because of the additives that are put into it. The final control of volatility is often achieved by blending with butane. The Reid Vapor Pressure test is used to measure the volatility of gasoline. The desired volatility depends on the ambient temperature: in hotter climates, gasoline components of higher molecular weight and thus lower volatility are used. In cold climates, too little volatility results in cars failing to start. In hot climates, excessive volatility results in what is known as "vapour lock" where combustion fails to occur, because the liquid fuel has changed to a gaseous fuel in the fuel lines.
In the United States, volatility is regulated in large urban centers to reduce the emission of unburned hydrocarbons. In large cities, so-called reformulated gasoline that is less prone to evaporation, among other properties, is required. In Australia summer petrol volatility limits are set by State Governments and vary between capital cities. Most countries simply have a summer, winter and perhaps intermediate limit.
Volatility standards may be relaxed (allowing more gasoline components into the atmosphere) during emergency anticipated gasoline shortages. For example, on 31 August 2005 in response to Hurricane Katrina, the United States permitted the sale of non-reformulated gasoline in some urban areas, which effectively permitted an early switch from summer to winter-grade gasoline. As mandated by EPA administrator Stephen L. Johnson, this "fuel waiver" was made effective through 15 September 2005.[7] Though relaxed volatility standards may increase the atmospheric concentration of volatile organic compounds in warm weather, higher volatility gasoline effectively increases a nation's gasoline supply because the amount of butane in the gasoline pool is allowed to increase.[
http://en.wikipedia.org/wiki/Petrol
Can't say I've noticed any difference. Last fall, shortly after getting the Jeep, I was getting about 24 - 25 on the highway. Stayed about the same all winter. Now, in spring weather, it's about 26, but the improvement is because I've slowed down a bit.
We had several warm days during the winter here in Indianapolis, Indiana. On those days where it was at least 45°F I saw a 1-2 MPG improvement over the days that were in the 20's or below, sometimes that would be one day to the next. So for at least those days, the gas blend (which is 10% ethanol around here) was the same.
Today, for example, it was 70°F and I got 23 MPG on my 8 mile commute (all city streets, 2 4-way stops, and 9 stop-lights) . During the winter I was happy to see 20 MPG on a very similar drive (amount of stoplights that were timed right). I park in my garage at night, so there is no "warmup" idling. During the winter I back out of my garage and go just like I do in spring/summer.
At some point, the increase in temperature is not going to help the MPG significantly, in fact it will hurt it a little because the cooling system will have to run. Right now I am getting mostly "free cooling".
I have also noticed a change as the weather gets warmer. I was averaging 21 to 22 MPG as it warms up we are getting up to 26 MPG. Currently have about 7000 miles on the clock.
I get 28 to 29 driving in to work @ 45 to 50 mph
We are in the summer blend right now
This is out of a 08 4x2 CVT , and I have the 2.4
The wife didn't want to drive a stick with kids in the car so that means a automatic for me
Can someone confirm or deny that our summer blend gas has less ethanol than winter blend and thus has more energy (ooomph) when detonated?
I have not seen a great improvement yet.
Noticeable difference on my part....much better millage!According to EVIC, during cold months i would qverage 13.5 liters/100 kms!(i reset avery fill up). Now, since early March, my average is 11 l/100k. Hope it lowers even more this summer!
There is definitely an improvement on my gas milage. Not sure if its because I changed gas stations.
For my first 4 fillups I went to ESSO ... got my jeep in Feb and filled up until mid March. Averaged 400KM to 410KM on a fill up. Switched to Petro Canada for a couple weeks .... first I thought ... this could not be ... then after the second fillup ... my gas milege is improving ......... I may hit 430KM!!!
warm weather milage
As I noted earlier in another thread, yes, the worl engine loves warmth. I do see better milage when it's running warm. Very natural event. The secret is to get it warm running around a bit before hitting the highway.
I don't know if warming up affects fuel economy, but I've always heard it's good in order to keep the engine healthy for longer. I don't like running the engine at idle for long (it's a waste of fuel), so what I do is go slow and smooth for the first few minutes. How I wish more cars had an engine oil temperature indicator.
If the street is empty, I also like to do some 'S' turns to warm up the tires, although it feels sort of embarrassing in case somebody's watching (I live in a big city). I just love taking care of the car and treating it well.
Driving around Mississauga all winter i was getting arounf 14.5MPG. On my last tank i got 18.5MPG around Mississauga. There have been some cold nights still so maybe it will get even better as it continues to warm. Just for the extra info, Driving around a small town in winter i was getting 20MPG. Winter highway was always around 23.3MPG. I'm very happy with the increase. Getting 14.5MPG makes me feel like I might as well be driving a 5 litre.
According to the EVIC, my winter mileage is several mpg lower on average than in warm weather. Right now (approx. 70 F), I am averaging 25 in the city and close to 30 on the highway - not bad. I am running the tires at 34 lb.
Absolutely a fuel mileage improvement!!!
Went from 27MPG average (4x4, 5-speed) to 55MPG :wow:
Although the Jeep sits in the garage while I take the Motorcycle to work :p
I've actually started tracking my milage and fuel consumption. Here it is over the last few months:
March 11, 2008
38.000L = 366.0km
9.63 km/L
March 18, 2008
39.154L = 411.2km
10.5 km/L
Mar 28, 2008
37.547L = 370.9km
9.88 km/L
Apr 3, 2008
37.206L = 390.7km
10.50km/L
April 16, 2008
34.243L = 363.1km
10.60km/L
Apr 21, 2008
35.60L = 403.7km
11.34km/L
So please tell me if my logic makes sense. So far in April I have averaged 10.81 km per liter of gas. So shouldn't that mean that from a 51L tank I should get 551.31km? That is what I assumed, but my gas light comes on at around 420km...am I doing something wrong?
-30 C gives me 14+ L/100kms, -7 C gives about 13L/100kms. I get BETTER mileage in the city, highway is at 110 to 120 Km/hr. Again, unplugging my battery for a while gives about 8 to 9 L/100km. Explain that! Oh I heart Saskatchewan.
