This should be in the knowledge base but I didn't see it there.
What is the difference between trail rated and not?
I think it's only a matter of which 4wd system it has.
Please correct these statement as I have not real facts to go on.
All freedom drive 1 systems are not trail rated
All freedom drive 2 systems are trail rated.
The only difference is that Freedoms drive 2 has low range and freedom drive 1 does not.
The low range is just a lower gear in the transmission and only in certain automatic cvt transmissions.
As such no patriots with a manual transmissions are trail rated and the only difference is a lower first gear in some of the automatics.
All patriots with 2.0 are fwd. All awd patriots come with 2.4 are center diff lock option and computerized braking traction control.
