Hows the new sun roof seal holding up? Can you explain what you had to do to replace it? My wife's 2012 patriot just gave puked a ton of water out of the front dome light. I checked the seals and sure enough its leaking in the corners. Drains function normally. Except I am sure they were froze up as it's been freezing and thawing for several days recently. Did you have to take the glass out? or can it be pulled around the glass while in the vehicle?
Hey jbelow2,
TSB 23-035-15 may relate to your vehicle:
SUBJECT:
Sunroof Leak Under High Water Pressure
OVERVIEW:
This bulletin involves installing a new sunroof service trough.
MODELS:
2011-2016 (MK) Jeep Compass/Patriot
2011-2016 (JC) Dodge Journey
2011-2012 (PM) Dodge Caliber
NOTE: This bulletin applies to vehicles within the following markets/countries:
NAFTA, EMEA, LATAM, APAC.
NOTE: This bulletin applies to vehicles built on or before May 05, 2015 (MDH
0505XX).
SYMPTOM/CONDITION:
The customer may describe a water leak at the rear of the sunroof when using a high
pressure touchless car wash.
