Painting the Interior
4.3K views 15 replies 12 participants last post by  Randoo-N-CJ
I am getting a new radio this week. I was thinking about painting all of the silver plastic trim green using krylon's fusion plastic paint.
I know you are wondering why green? Well my patriot is white and the interior is black. I am a Philadelphia Eagles fan so I thought why not paint the trim while I am installing the new radio.
Has anyone painted the silver pieces? Do the ones on the doors just pop off or not?
Thanks
Normally I would recommend against doing this, but my inner Eagles fan wants to see it done too! :p
In all seriousness, 90% of the people who attempt this wind up "junking" up their car. I was guilty myself when I was younger. The silver plastic panels all pop off real easily and sadly they do scuff up pretty easily. Be sure to take your time and perform all of the necessary steps. And be sure to get plenty of pics of the process!
did that to previous cars
i say go for it,
looks great when done,
couple things,
Must prep the surface, just painting an already painted surface will cause it to flake off,
and depending on the plastic, using certain thinners to prep the surface could cause the plastic to bubble, leaving a rough surface.
usually the softer plastic is more prone to this than the hard plastic pieces.
also remember to get the right primer to prime plastic.
Packer green ;).....just make sure you prepare the surface. Take a scotch bright pad to it first. Use a good primer. and Krylon? I've had experiences with Krylon where it doesn't seem to get hard enough and dry enough to use where fingers will touch it a lot, or where is will get that hot inside a car. I'd suggest and automotive exterior paint. Those always get real hard dry and shiny. Probably give it a coat of wax after a couple of weeks. Have fun. PICTURES!
Almost forgot to mention... a quality wax and grease remover works wonders when painting plastics. Dealers often use silicon type sprays to make the interiors shine before you leave the lot. Plastics absorb these sprays real easily and you'll need to do some pretty thorough decontamination if you want quality results.
Thanks for all the input. I know the krylon plastic paint says you don't need to prime the surface but the more I think about it it may be better to buy an automotive paint and prime it plus clear coat it. I think maybe dupli-color or some other brand may even make a paint for plastic. Years ago I painted the whole interior of my 94 chevy truck I had. I can't remember the brand paint I used though. It did hold up pretty well.
Primer isn't necessary. It's actually very over used. I would recommend primer only if you were painting on raw plastic or metal. Seeing how your trim pieces were already painted once, the prep work has already been done to the raw plastic. It would be a waste of $4 to buy a can of primer.
mate black painted central console
Hello, maybe it's a little too late to reply, but I've painted both the central console and the arm controls and my RIOT.
I've painted them all mate black, and they look really great, but I'm not sure how the green goes on it.
So if you decide to paint them, let me suggest you to paint them outside the car, so you can see the parts and details on them, and of course to avoid the green spots on the interior.
The central panel includes both the air conditioning and emergency lights controls and they're not detachable, so if you decide to take the console cover off, firs make sure you disconnect all the controls correctly and to connect them all before you put the panel on again. Once you detach the panel, you'll only have to mask the controls in order to not paint any one of these parts.
I suggest you to use a primer according to the paint you decide to use, because the panel has already a fished material that maybe is not 100% compatible with the new paint, and the primmer will help on it.
I’m adding a photo.
Cheers.
guinchard
I would say don't do it either. Im sure a shop would charge less than 100 bucks to do it and atleast it won't make the inside of your car smell like spray paint after. you've got a brand new car that looks great, I think you'll regret a spray paint job on it. spend a little extra and get it done right with no regrets. if it looks like **** from a shop, they can fix it and its their fault not yours :)
Another alternative?
Maybe buy an extra set of the trim and have it painted (or DIY) and put them on until they show signs of wear. Replace with the stock units at that time perhaps?
I've been thinking of doing this but painting it with the exterior color, in my case, SBO. That's about the only way I'll get a coordinating color scheme is if I try that. Since I don't have the talent to try that myself, I would have our local body shop do it (cuz they are damned good too!).
Just another idea I thought worth mentioning.:)
