Opinions on new sound setup?
2K views 4 replies 3 participants last post by  jakeheinlein
Hey guys. Got a 2014 Jeep Patriot and NEED a sound system upgrade. Looking at the following. Just wanted to make sure it will all fit and work compatibly with my factory specs so all I need is someone to help with install but no major fabricating will be needed. Btw, on a tight budget so it's kinda cheap.
Kenwood Head Unit BT:
https://www.walmart.com/ip/Kenwood-...1&wl6=&wl7=&wl8=&wl9=pla&wl10=108360736&wl11=online&wl12=53849498&wl13=&veh=sem
Polk 6x9 Speakers (pair of 2):
https://www.amazon.com/dp/B000P0R6KW/ref=cm_sw_r_oth_api_467Syb3GD5GQH
Subwoofer with built in amp:
https://www.walmart.com/ip/Kicker-PT250-10-Subwoofer-with-Built-In-100W-Amplifier/32983978
That should all fit without a problem. Double check the mounting depth of your 6x9's but it shouldn't be an issue.
I have become a fan of the built in amp & sub box as it is less to deal with when installing and takes up less room compared to separate components. And over my time of car stereo i have learned that less is more. ill take sound quality with trunk space over "feel the bass flex" any day. If you were to tell me that when i was younger and I'd tell you that you were too old.
