Hi, I want to know if anybody had step by step instructions on how to remove the door panels on a 2012 Patriot? Thanks
M MrShoehorn 126 posts · Joined 2011 Add to quote Only show this user #2 · Feb 11, 2013 Working on one for you right now!
M MrShoehorn 126 posts · Joined 2011 Add to quote Only show this user #3 · Feb 11, 2013 (Edited) Tools Needed: 10mm socket (deep well or have extensions) T-20 Torx T-25 Torx Trim Removal Set Step 1: Remove cap in door bin http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11376&stc=1&d=1360626239 Step 2: Remove T-25 torx screw http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11377&stc=1&d=1360626490 Step 3: Use the trim removal tools to pop the clips holding in the center armrest. http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11378&stc=1&d=1360627006 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11379&stc=1&d=1360627006 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11380&stc=1&d=1360627006 Sorry maximum of 5 files continued on next post. Attachments 094.jpg 34.9 KB Views: 853 095.jpg 29.3 KB Views: 774 101.jpg 45.7 KB Views: 851 117.jpg 47.4 KB Views: 945 118.jpg 50.5 KB Views: 855
M MrShoehorn 126 posts · Joined 2011 Add to quote Only show this user #4 · Feb 12, 2013 Step 3 Continued: You'll pop all the upper hooks using the tools then work on the bottom half. The following pictures will show you where the hooks are located. http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11381&stc=1&d=1360627284 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11382&stc=1&d=1360627284 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11383&stc=1&d=1360627284 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11384&stc=1&d=1360627284 http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11385&stc=1&d=1360627284 Speaker removal on next post. Attachments 119.jpg 33.7 KB Views: 816 111.jpg 39.5 KB Views: 717 112.jpg 23.6 KB Views: 690 114.jpg 27.7 KB Views: 668 115.jpg 29.1 KB Views: 733
M MrShoehorn 126 posts · Joined 2011 Add to quote Only show this user #5 · Feb 12, 2013 Speaker Removal: Step 1: Pop off the speaker grill, this is pretty easy and once one pin pops the rest will following with just a little force. http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11386&stc=1&d=1360627624 Step 2: Remove the T-20 and T-24 Torx Screws, just remember there location they are different lengths. http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11387&stc=1&d=1360627624 Step 3: Disconnect the speaker wires. http://www.jeeppatriot.com/forum/attachment.php?attachmentid=11390&stc=1&d=1360627624 Attachments 120.jpg 50.4 KB Views: 696 121.jpg 29.1 KB Views: 809 124.jpg 28.7 KB Views: 622
JREP Discussion starter 16 posts · Joined 2012 Add to quote Only show this user #6 · Feb 12, 2013 Thank you very much.
M MrShoehorn 126 posts · Joined 2011 Add to quote Only show this user #7 · Feb 12, 2013 No problem, I hope those answer any questions you had.
Metaxa 4,018 posts · Joined 2012 Add to quote Only show this user #8 · Feb 12, 2013 This should get into the Knowledge Base. Where is a moderator when you need one, eh?
mrcody77 235 posts · Joined 2011 Add to quote Only show this user #10 · Feb 14, 2013 I second that!! epper:
Z Zooki 173 posts · Joined 2012 Add to quote Only show this user #9 · Feb 13, 2013 Good stuff, thanks or he write up
