How AWD works on Patriot
12K views 10 replies 7 participants last post by  inouk
From 2008 Patriot service manual:
OPERATION
The all-wheel-drive system requires no driver input or control. Under most driving conditions, it is passive and power is transmitted to the front wheels alone. Unlike all-wheel drive systems that rely on pumps or viscous fluids to transfer torque, this system requires no front-to-rear slippage for activation. This allows the system to transfer torque solely in response to accelerator pedal position. If the driver is asking for a lot of power, the system immediately starts clamping the electronically controlled coupling (ECC), transferring a high percentage of power to the rear wheels. This avoids front wheel slippage, as power to propel the car is transmitted through all four tires. This mode of operation is called open-loop operation in that there is no feedback to affect the torque transfer.
A second, closed loop, operating mode uses feedback from the wheel-speed sensors to determine the appropriate torque transfer. When the front wheels slip, the All Wheel Drive (AWD) Control Module tells the ECC to start clamping, sending power to the rear wheels. Attempting the same aggressive launch described above with the front wheels on ice and the rear wheels on dry pavement, the ECC sends even more torque to the rear wheels to minimize slippage and launch the vehicle. Both modes are always active with the closed loop mode layered on top of open loop mode to increase torque to the rear wheels when needed to maintain traction in extreme cases.
Power to the rear wheels is modulated under the following conditions:
o Slipping on ice while backing up will send a lot of power to the rear axle
o Loss of traction while traveling at freeway speeds, for example hydroplaning on a puddle of water, will send very little power to the rear wheels because the controller knows at those speeds a lot of power is not needed at the rear wheels
o A third condition, which is independent of the others, uses wheel speed differences to determine when the vehicle is turning in a tight circle. This condition, which is indicated by a large discrepancy in side-to-side wheel speeds, causes the electronic control module to reduce torque to the rear wheels to prevent binding in the driveline. The electronic control module is always checking for this condition as well.
o A fourth condition that is unique to this system is to influence vehicle dynamics. Other systems limit AWD to aiding traction or providing off-road capability. The primary focus is on launching the vehicle or going off road at speeds up to about 25 mph (40 km/hr). Above that speed range, they use it to limit wheel slip for traction. On this system, additional ECM calibration controls torque to the rear wheels for improved handling in the 25-65 mph (40-105 km/hr) range. In this speed range, the system increases torque to the rear wheels during cornering with the throttle open to make the car turn more easily - make the handling more neutral. This is more readily accomplished with an electronically controlled system, than with viscous-coupling or gerotor systems that require some degree of front-to-rear slip to transfer torque to the rear wheels. Above 70 mph (113 km/hr), the control strategy provides minimal torque to the rear wheels under normal driving conditions to aid fuel economy.
The control module also interfaces with the Electronic Stability Program (ESP) and traction control systems. The interface allows the ESP system to use the ECC to help gain control of the vehicle. For this purpose, torque transmitted to the rear wheels by the ECC can be reduced. This system is not traction control. It only works on situations where front-to-rear traction varies, for instance, front wheels on ice, rear wheels on dry pavement or climbing steep grades. AWD does not aid side-to-side traction. ESP does that through brake intervention on this system.
Sounds like a lot of marketing speak to me. The ECC is either engaged or not. The system can slip it, but that accelerates wear. 100:0 F:R torque split or 50:50. There is no other, no in between, no "more torque to the rear." Since all MK's have stability control that requires a steering wheel angle sensor, the 4WD system should be using that to understand whether the car should be turning, not wheel speed differences.
APT, did you see inside ECC clutch? I may be onto something:
Electromagnetic clutches are also often found in AWD systems, and are used to vary the amount of power sent to individual wheels or axles.
http://en.wikipedia.org/wiki/Electromagnetic_clutch
I know that wikipedia may not a reliable source, but... It makes sense.
Note the above all function like 2WD when clutch pack not engaged, and like 4WD highrange in a part time 4WD system when the clutch is engaged (usually by computer although some allow manual control). Some in this category have varying degrees of control in the torque distribution between front and rear via allowing some of the clutches in a clutch pack to engage and slip varying amounts. An example of a system like this is the BorgWarner i-Trac(TM) system. Note: the Haldex Traction based car list was created from the list on Haldex Traction corporate web site: | Haldex Cars. Interestingly, a version of the BorgWarner ITM3e system is used on 2006 and up Porsche 911TT's. These Borg Warner systems were the forerunner of the popular Volkswagen Group Direct-Shift Gearbox (DSG) gearbox.
http://en.wikipedia.org/wiki/Four-wheel_drive#Clutch_pack_coupling
I written parts of some service manuals. The quote above would not be used to diagnose anything. They usually read like flow charts, check X, is it A, B, or C, If A, check Y, etc.
One can cycle a clutch to effectively get something between 100:0 and 50:50, but I doubt the system in our MKs are designed to take much of that. These are not $100k+ AWD Porsches.
Regardless of what any descriptions say, the MK 4WD system is mechanically simple and effective. Personally, if I could have one more mode of never locking up the ECC which would take just another switch a software update, it would be perfect for all on-road situations.
I think the MK's AWD system works just dandy, and its a shame that some of the larger magazines haven't compared this AWD system to the subaru and other makers AWD systems.
From my experience it does very well and in reality I don't see much difference in the "AWD" mode and the 4x4 locked mode in the slippery stuff, of course the 4x4 low and locked works very well but is only on the FDII Pat's.
In short its a awd/4x4 system that needs zero driver input and it just works great:smiley_thumbs_up:
I went to my dealer (I was on my way home) and I asked the salesman about AWD system on Patriot.
He was very categoric: the electric clutch that engage the rear wheels is either engaged or not. There's not such thing as variable torque. He also told me that the 4WD T-handle will put Patriot on 4WD with the same amount of torque on frond and rear wheels only under 50km/h. Above that speed, it's disengaged by default but will be engaged when needed.
I changed myself dry and wet clutches, cars and ATV, I know that by letting it slipping for a long time it will wear rapidly. So, I'm always wondered what kind of clutch it was on Patriot.
The service manual doesn't talk about it, it just says to change the entire electric clutch system if we need to. It's not like the main clutch where we can see inside (pressure plates, clutch plate, diaphragm, etc).
So, if it's really a simple system that it engages or not, I don't call it a "variable torque" as marketing term but a lie.
It's so complicated to get the right information about AWD system...
