Halos
8.5K views 14 replies 8 participants last post by  JimiTheSaint
I really want halos for my patriot but I'm finding them absolutely no where. Does anyone know any website that sells them? Or any other cool after market headlights for a 2014 patriot? Also, does anyone know if you can use wrangler headlights on a patriot?
#2 · (Edited)
you can only use MK headlights on a patriot. Nobody actually makes halo headlights, but you can buy aftermarket halo rings and install them on/in the headlight. if you were to install them inside the housing you would need to "bake" the housing to make the glue all gooey then take the clear front piece off... OR you could just tape the halo on the outside and be done with it. You can, however, get halo fogs. Creation has some I believe. They are dublights, or some ridiculous name like that. Ebay brand stuff...
[EDIT] I just measured the lights, and they arent a perfect circle, they have a slight oval shape, so I have no idea how to make custom halo's unless you use LED tape
#3 · (Edited)
If you want Halos for your headlights you would need to have them retrofitted on. Me and Laxmaddnesshero are both running full retrofits. You'll also need somewhere to mount the rings, so most likely you'll need to projector retrofit while you have them open.
If you don't feel comfortable taking apart your headlights I'd highly recommend having a professional retrofitter open them up. I'm not sure where you are located, but Theretrofitsource.com is a great site to read about the process, and you can also find installers. http://www.theretrofitsource.com/authorized-dealers
Here is a shot of my custom headlights, made by "Transformalights" who is one of TRS authorized dealers in Florida.
Edit: Also I moved this to Exterior rather than Build Threads. Please be a bit more cautious when starting threads.
Or glue a LED ring inside the headlight after you opened them up;
@ joriss those look awesome! @moparnumber1 thanks for the link. I may have found my next modification :) do you all think the product is quality being that cheap and all?
