1 - 4 of 6 Posts
Di Ginorio
· Registered
Discussion starter · #1 ·
Comrades, I have a problem and I need you to give me some help. I changed the engine mounts on my Patriot. the driveshaft, the front and rear axle. I put new tires on it, I balanced it, in short, the entire front is new. but it keeps shaking and it's damaging my swaybarlinks again. What can you say to me ?
Discussion starter · #3 ·
When does the shaking occur?
Is it when at idle in park, or when stopped while in gear and braked, or only when moving?
If only when moving, is it only during acceleration, or at a certain speed, or when turning?
Have the rotors been checked to see if they are warped?
Have the front control arms been checked to see if the bushings are loose or cracked / worn?
Are the struts in good condition; no leaks and you cannot bounce the car?
Was there any abnormal wear on the old tires?
I changed the rotors, the brakes,new tires , swaybar link, truts .Everything in front drive it new.
I don't know what else to do. when it goes to accelerate when im driving it start the .shakes.i charfe the spart plug and everything
1 - 4 of 6 Posts
