Follow the service minder or change oil at 3000 miles?
3.7K views 17 replies 15 participants last post by  todde702
How do you do it? On my Patriot, the minder comes on usually well past the 3000 mile mark after I've already changed the oil. I wonder if I could save myself the trouble and just use the service minder or if I need to stick with the 3k rule.
what is considered an "early break-in change"?
Well, I wouldn't go 13,000 kms on factory oil in a brand new engine...but that is what the book calls for.
Personally I changed first time at 7,000 km (4,400 miles +/-).
Then I changed at 13,000 to keep warranty up and due to the miles I drive and how I drive them, my oil change light doesn't come on until I'm at warranty called for 13,000 km changes. Which for me is every 4 months, so 3 times a year.
Make sure you use a filter capable of working that long, no Fram junk...I use a high mileage filter from a subsidiary of Purolater (I think)...I trust my mechanic...his recommendation.
My oil draining out looks as new...that clear brown colour, no dark to it at all, no smell, no thickening. I haven't sprung for a test as I'm confident that my daily drive is burning the contaminants out and that the oil is doing its job even over that number of kms.
Our oil, 5-20, is all semi synthetic or full synthetic, depending on whose brand it is so it will do the job.
Now, I drive a 80 kph highway 40 minutes up to my work area then do 4 hours of what most of you would call off-roading as I go from mine to mill to plant to whatever and then I do 45-50 minutes of 110 kph back down.
Its the stop and go, city stuff that is severe service, my highway jaunts keep my vehicle running great on long oil changes...your mileage may vary as they say.
Around here an oil change, on sale, is $40. I spend $120 a year...if i was to change every 3,000 miles or 5,000 km I'd spend $320 and be tossing a lot of perfectly good oil.
The first 2 or 3 oil changes I did were at 3,000 miles. The last two have been when the light came on around 7,500. I use Mobil 1 full synthetic, and do enough for the warranty
Sent from my Galaxy Nexus using AutoGuide.com App
I do whatever the jeep tells me, so every time that comes in.
Modern engines have such tight specs and modern oil formulas, its best to just go with what the manufacturer suggests.
Extended break ins for engines no longer exist. Most cars/trucks are 0-500 miles now and its usually to break in other drivetrain components other then the engine. Usually a few WOT's are done to seat the rings is all it takes to break the engine in. The engineers have done plenty of testing of oils to determine a quick change after driving a new engine is not needed anymore.
I change mine when the change oil message pops up in my odometer. I figure the engineers that designed the algorithm for calculating oil life must know a thing or two about oil, and since Chrysler also gave me a lifetime powertrain warranty, that it must be ok to follow. I usually average 5200-5600 mile intervals, though the last two changes the message appeared at about 3800 mile intervals. Not sure what changed, other then the wife has been driving it a bit more :confused:
I usually change the oil within a 1000 miles of the Jeep telling me to change it which is usually around 6000 miles or so. It did go off earlier than that in Januayr, but that was after really working the engine hard for a week pulling a trailer across the country (SC to NV). So I think the computer can tell when it needs changing.
I'm at the dealership right now waiting for my first oil change to be done. Today is 6 months to the day since I picked up my JP new with 2.5 km on it, I wondered the same thing as you but decided to follow the OM and have it changed every 6 months or 13,000 km. For me 6 months came first as I'm only at 11,000 km, but obviously if the oil change indicator had of come on earlier I would have been here earlier. I've also managed to fill it up using only Shell gas so far, about 26 fill-ups, not sure if that makes a difference or not.
I change my oil every 4,000 miles, not dependent on the warning light or owner's manual.
Keep in mind that the Jeep does not analyze your oil to determine whether or not you need an oil change -- it's dependent on mileage and your driving habits.
Actually it takes outside temps, engine temps, stop 'n' go and/or highway driving into consideration to calculate an oil life. So long as the engine isn't severely worn where it may have more then normal blow-by (or anti-freeze contamination), it's going to be pretty accurate.
