This is the full list of questions I asked. I only pulled a few of the questions for the post. But here is the full email. Let me know if any of you have other questions I can ask them:
RE: Jeep‎
From: Rocky Road Outfitters (gwbuild@rocky-road.com)
Sent: Tue 8/21/07 3:10 PM
To: Marco Colindres (marco.colindres@hotmail.com)
That's fine
These are my questions. If you can answer them that would be great.
1) Because this is a prototype and free of charge, if something were to go wrong with installation, who would be held responsible and what is covered?
Whatever we design and install, you get for free. All our steel parts are carry a lifetime warranty. If something breaks, we will send you out a new piece. Never happens though. Lifetime guarantee means longer than your Jeep is ever going to last.
2) What processes do you take before going through with installation?
Not sure what you mean by this.
3) By how much will lifting the Jeep affect my gas mileage?
A lift usually has little to no effect. What is going to affect mileage more is if you change your tires to a more aggressive tread. Larger beefier tires come with a little 'cost' in fuel economy.
4) Are you looking to lift it 2.5" or 3" or is that up to me?
We believe the max lift height on your vehicle is going to be in the 2-2.5" lift range. Won't know this until we get our hands on the Jeep. Also, we need 3 days for the Rockrails. For the lift, it would be especially helpful to get the vehicle for Tues-Friday. Designing a suspension requires a little more engineering and time than just doing a set of rock sliders.
5) I heard that a lift and larger tire offset the speedometer. Do you calibrate the computer to match the size of tires?
Again, the lift does nothing to your speedo... or fuel economy. Going to larger tires will change the speedo reading. For most people, this is a benefit as the mileage reads a little less and so your vehicle warranty lasts a little longer. If you get larger tires, just use the 10% rule. If the speedo says 30, you are really doing 33. If it says 50, you're doing 55. And so on...
6) Do you know the max tire size I would be able to put on the patriot with a lift?
Nope. Won't have any idea on this until we can get a lift designed.
7) There are many at the Jeep Forum that want to know how long it would take to get the lift available to others once the specs have been figured out?
We would hope to have the lift figured out and installed in the same week. Then we let you run it for a few weeks just to see how it does. If all goes well, then we can start selling them.
Your company sounds very credible and look forward to helping with you on figuring out a lift for the patriot. I know many Jeep Patriot owners will be greatful.
Thanks
Marco
