I am thinking of buying a Patriot and was wondering what kind of mpg people are getting with their Trail Rated CVT models? I see the epa is listed at 19/21updated with the 2008 figures but I am hoping for more than that.
Why does having a low gear that you can switch into, affect the gas mileage when you're not using it? I think all they did was gear down the entire range of the transmission.QUOTE]
Front wheel drive transaxles are a little harder to think of or get at the final drive ratio. Like a rear end has 4:11's or say 3:55's. The trail rated still has only a single speed transfer case, no Hi & Lo range. They got the lower ratio by giving it a lower final drive ratio, therefore your hi gear is lower than the other auto.
I got the CVT, if I had it to do again I'd get the CVTL. Mostly because of the extra cooling, skid plates, 1" more lift (springs are 1" longer). Use the extra wheel well clearance to put on taller tires. Taller tires will help do the same as a little taller gear, and the CVTL will have more torque at the ground to handle them.
Several threads are devoted to the mileage issue. Your engine is nowhere near broken in. Mileage should continue to improve for approximately 2000 km but I don't think it will get 25% better. It is best to compute mileage on a monthly basis rather than each fill up. Monthly computing averages out the inevitable variances such as when the pump shut off, quality of the fuel, weather, traffic, etc.i am freaked out about the mileage issue.
Agreed, the dealer I bought my Patriot from told me flat out that the FDII Pat would still get 30mpg on the highway. Of course I knew that was BS, but it just shows what the dealers will say.The dealers make it seem like all Pats are 30 MPG, so I was maybe a lil optimistic!
