I was doing some checks this morning while I was at work.
I wanted to see how hard it was gonna be to install the Aftermarket trailer wiring adaptor later when I got off work.
I remembered reading that on Trailer prepped Riots that had a plug taped to the harness behind the grommet on the left side tail light assembly.
On aftermarket adaptors you must run a wire to the battery for power. This is the same for the harness for the non-trailer prepped Riots.
You must remove both rear lenses for the wiring.
On the left side, where the reverse light and tail/stop light wires go into the body is a grommet.
This is seen in the next picture.
I pulled my grommet and to my surprise
The red circle is where the wire was taped.
The wire is red with a purple stripe
Sorry I didn't take a picture of the wire when it was still taped in place but I was so :banana: that I just forgot about it.
This is a picture of the plug itself.
I did put a meter on it and it has constant (ALWAYS HOT) 12v source
I am gonna assume that it is for the trailer package as I don't know what else would be hooked up there.
I installed the wiring and the hitch today. It took 45 mins including time to put it on the lift and look for tools.
You don't need to have a lift when you work on it but it sure does make it easier..
I did use the wire I found for power.
Everything works fine.
I doubt I will ever tow anything (because I don't have the oil cooler YET)
CLICK PICS FOR HIGH RES
Picture of the left (US DRIVERS SIDE) tail light lense removed
Picture of the adaptor stuck to the car using the supplied double sided tape
notice the red wire coming off of the adaptor and going into the grommet. I did not add any wire to this wire, I just cut the buttsplice off and used a clamp-splicer (lack of the proper word) shown in the next picture
Picture of the connectors wrapped up with RUBBER tape
