Hi Guy's,
I have installed the RRO lift on the Pat.
The front end is quiet as but the rear end makes some noises.
Symptoms are as follows:
1. While reversing out of the drive way or pulling into a drive way and when one wheel is higher than the other the back end creaks.
2. Going over larger bumps in the road the back end makes noises.
If at a stand still I open the tail gate and push the end up and down all is quiet.
3. When I go over changes in road and go over a crease in the road it feels as if the back skips over the bump instead of rolling over the crease in the road.
Man it really echoes from the back to the front.
I have lubed all joints at the back a few times now and its still there.
I'm wondering if the springs need to settle now a bit after things being lifted and that the Pat needs a few k's to settle down.
The front end is all fine.
I've called ARB who installed the lift for me have booked it in after lunch on Fri for them to look at.
Just wondering is anyone else had any probs after install such as this and then it settled down some what?
I am wondering if ARB used any grease on the bushings and sleeve with the new arms as per the instruction from RRO.
