Center Console Removal???
36K views 10 replies 8 participants last post by  sskelmar
Ok i need help. I want to remove my center console for some cupholder modification, but I am nervous about breaking any fragile clips. Has anyone done this yet that could lend some advice?
Thanks
REMOVAL
1. Set the parking brake lever in the up position.
2. Remove the two screws from the console bin.
3. Lift the console (4) up at the front from underneath right hand and left hand sides of console base at the same time and release the console clips (1).
4. Lift console from rear and release the rear clips (3).
5. Disconnect the electrical connector (6).
6. Lift the console (1) up and over the park break lever (2) and remove
I have a 2010 and mine is a bit different. On mine I pop the plastic base of the shifter boot out. Not around the chrome, but the plastic on the outside of the chrome. The rest is pretty obvious. There are four screws, and then carefully lift up the console and unplug the 4WD switch which also carries the wires to the cup holder lights..
I haven't been on the forums for quite a while, alot going on in life.
Finally got a chance to start reading all the posts I've missed and I need to say THANKS Davecanuck!! that was a great detailed explination for removing the center console =)
