This morning, I stopped to put gas in my Patriot and went inside the gas station for a coffee, while it was filling up. When I got back outside, the pump was finished running and I pulled it out, only to find the plastic piece inside the gas cap had come loose somehow.
The metal neck you put the gas pump nozzle in was moving around because it no longer had anything anchoring it securely near the top of it, and the plastic piece slid partially down the neck.
Here's a link to a picture I took of it with my phone camera real quick, after trying to pull the plastic part back up enough so you can see it in the photo:
http://dl.dropbox.com/u/6706105/gascap.jpg
Is there some way I'm supposed to be able to just snap this back into place, or did something break behind it and I need to order a new part??
