Hello everybody , it seems to me I may need to replace the resistor of the blower fan. When I turn on the fan it hardly blows at the lowest speed and then when I turn the knob to higher speed it kind of blows but becomes noisy. So I did some quick investigative reading and as I have discovered the symptoms may be a failing resistor.
If you have replaced yours did you find the job difficult? After you removed the glove box you just unscrewed the old one and replaced it with the new one? Would you say it's 5 - 10 minute job and no special tools are required?Oh yes, one more thing. The battery has to be disconnected. Do I have to disconnect the positive cable or if I just disconnect the negative clamp the work can then proceed? I know the easiest would be to drive the car into a garage and let a professional do the work but everything nowdays is so expensive plus I had to replace the tie rods again couple of weeks ago. At 70 000 miles I'm on third set of tie rods and I do all my best to avoid any pot holes.This time I did't install mopar but dorman. Thank you very much for your help ,I really appreciate it.
