225/70R17 Tires
8.1K views 17 replies 7 participants last post by  13Patriot
I know they are 29.4 inches in diameter. Without a lift, but with 1.25 inch spacers, would they rub anywhere in the wheel wheel including the pinch weld? Or for a tire this large in diameter would I need to be lifted, have the pinch weld mod, and 1.25 inch spacers?
Thanks!!
There is no TA KO that would fit on the 17" rim (at least not on the available sizes on their website) you would have to drop to a 15 or 16" rim.
Biggest things to remember on tire sizes, 30" overall diameter and under 9.5" wide, if lifted and running spacers on stock rims or an after market rim with the proper backspacing.
if not lifted under 8.5" wide and under 28.5" over all diameter, and can be done without spacers usually.
