215/60R/17 vs P215/65R17
15K views 11 replies 7 participants last post by  Madelinot
i like the white wall on the all terrain 65's and the overall size look. if im gonna be driving 95% pavement, how bad would they be outperformed? $140 upgrade isnt significant, so what really is at stake...
The P215/60R17 has an O.D. of 27.2" while the P215/65R17 has an O.D. of 28.0". I believe that the bigger tire is only available with the FDII package which has some funky different final drive ratio to keep the speedometer/odometer correct. If I'm wrong then how do they correct for the error?
The tire size is so close I doubt you will see a differance in gas , but the FDII in the 2.4 should drop a mile or two at lower speeds . "This is my opinion only ". I have not seen a window sticker on the money with milage unless traveling down hill with wind at my back . My cherokee didnt change at all when I jumped 1" in size , I would get same milage on a full tank within 5-10 miles of fill-up .
They call the 215/60R the touring and the other one the off-road tire.
What's that mean on the road, the ride could be better with the touring, I don't know, I have to make a choice, I'm never going off-road, I will order a Limited 4X4, 5 speed, here in Canada it's $250.00 for the all terrain tire with white letter, the 5 speed come with the 215/60R black.
If the ride is better with the touring I will forget the white letter.
I've been running on snow tires in winter for the past six years on my Ford Focus, and definitely noticed a difference in traction and stopping. My Patriot order includes the Wheel Group, with the 17" tires and aluminum wheels. I like the look of the wheels, but now I wonder if the tires will give the same type of performance. Then again, we're comparing front wheel drive to 4x4 on a vehicle that is close to 700 pounds heavier. The tread on the Wrangler SR-A tires looks more aggressive than the 16 inch. It would be great to try them back to back in winter driving conditions.
What brand/model winter tire are you using? For my Ford Focus, I bought a second set of rims at Canadian Tire and keep a set of Ultra Grip Ice tires (4) mounted. Changeover in Spring and Fall is quicker and easier. Getting a second set of rims and winter tires is a possibility for the Patriot, although a car dealer (not dealership) I know says it won't be necessary.
