Order banks opened today and the build and price feature now works on the Jeep main site for anyone interested.
Agreed. Base Rubicon for me please.If I'm going to spend 30 grand or more on a vehicle I'll actually be getting a "real Jeep" not an ugly wanna be "real Jeep"
For air, I have a pump that uses the cigarette lighter, and could plug my compressor into the power inverter too (not the one that comes with Patriot, but a better one I carry with me), but most folks I know use a can, and I have a friend who's family has these, use link, that are really cool for portable compressed air:I've been thinking that converting the AC to an air compressor for my tires would be the best use of that extra drag on my motor.
At least having these things you can select helps when you can't engage 4WD manually like you should be able to. I could have done without Select-Terrain. Just do the 4WD like they did it in the Patriot. Flip the switch when it is needed. I don't see how having a bunch of different driving conditions to pick from is less driver input like Jeep claims was the motivation behind it all?• Auto – Fully automatic full time four wheel drive operation can be used on and off road. Balances traction with seamless steering feel to provide improved handling and acceleration over two-wheel drive vehicles.
• Snow – Tuning set for additional stability in inclement weather. Use on and off road on loose traction surfaces such as snow. When in SNOW mode (depending on certain operating conditions), the transmission may use second gear (rather than first gear) during launches, to minimize wheel slippage.
• Sport – This mode alters the transmission's automatic shift schedule for sportier driving. Upshift speeds are increased to make full use of available engine power. SPORT mode is not available when 4WD LOW is selected.
• Sand/Mud – Off road calibration for use on low traction surfaces such as mud, sand, or wet grass. Driveline is maximized for traction. Some binding may be felt on less forgiving surfaces. The electronic brake controls are set to limit traction control management of throttle and wheel spin.
• Rock – Off-road calibration only available in 4WD LOW range. Traction based tuning with improved steer-ability for use on high traction off-road surfaces. Activate the Hill Descent Control for steep downhill control. Use for low speed obstacles such as large rocks, deep ruts, etc.
I'm with you, although I think I should truly reserve judgement until after I drive a Cherokee. My reasoning is this... my wife's commander is an AWD system (QDII). I'm almost completely positive that in normal street conditions the rear axle gets nearly 100% of the torque. If the rear axle turns faster than the front, a gerotor pump kicks in and applies hydraulic pressure to a clutch pack to apply more and more torque to the front axle until both the front and rear axle turn at the same speed.Yeah, looks like ADI is a fully automated system. Nothing the driver can do to engage/disengage 4WD. I do not like that at all. That basically means it is like all the other small suv's and cuv's out there with automated AWD.
