2013 oil change interval = 10,000 miles or twelve months
16K views 15 replies 7 participants last post by  Phantom Rider
Someone posted a clip of a 2013 OM the other day. The required max oil change interval has been extended.
From the 2011 Patriot OM
Under no circumstances should oil change intervals
exceed 8,000 miles (13 000 km) or six months, whichever
comes first.
From the 2012 Patriot OM
comes first.
From the 2013 Patriot OM
exceed 10,000 miles (16,000 km) or twelve months,
whichever comes first.
What changed to extend the max (read Warranty Coverage) OC interval by 2,000 miles/6 months??? The maintenance chart has also changed for 2013.
Full synthetic oil? The oil change interval for my Saab that used synthetic was similar.
Nope...
Engine Oil
We recommend you use API Certified SAE 5W-20 Engine Oil, meeting the requirements of Chrysler Material Standard MS-6395. Refer to your engine oil filler cap for correct SAE grade.
GTX 5W-20 meets the spec...
Synthetic Engine Oils
You may use synthetic engine oils provided the recommended oil quality requirements are met, and the recommended maintenance intervals for oil and filter changes are followed.
No "Will, Must, Shall or Required"...
#3 · (Edited)
I seriously doubt Chrysler changed anything on this motor at all. I think after Dixie came in with a blown engine at 100,000 miles, they figured it to be a good time to increase the oil change interval :doh:
I wonder if they can reprogram my 2011 oil minder to match the 2013
Sent from my Nexus 4 using AutoGuide App
The OLM programing may not have been altered. Time and miles are not part of the formula for the OLM. It has to do with temp, idle time, RPM's, and other factors related to actual use.
Lots of car mfg's are starting to extend out to 7500-10,000 and a year. Modern oils can do it in a healthy engine. Also, I am going to assume here that with the vehicle being equipped with an OLM car mfg's are figuring that will trip and result in the oil being changed sooner in vehicles that are used harder.
I would like to see Chrysler(Jeep) back spec the older Patriots to a year and 10K. I only do about 7-8K a year tops now and I run synthetic. A year and 10K would be good for me.
I will have my first oil change at 1 year mark, Im at 2450 miles today, next month on the 14th will be 1 year.
#11 · (Edited)
Ive been driving almost a year and my oil change indicator hasn't come on...
1 year mark is February, 14 2013
Im at 2450 right now
