Hello, I've recently run into some issues with my Patriot transmission.
2012 2.0 5 speed FWD no 4x4, 76k miles.
When I start it up and let the clutch out, the transmission makes a very loud grinding noise.
When I push the clutch in it is completely silent.
When I'm in gear and accelerate, it makes a whirling noise and a metal on metal grinding noise.
Has anyone else noticed these issues with the 5 speed?
It has gotten progressively worse over the last month.
I just dropped it off at a transmission shop to have it diagnosed.
I've done my research and the likely culprit is the input shaft/input shaft bearings.
I'm hoping the syncros aren't shot and the gears aren't worn too terribly
When they drop the tranny and look at everything I'll just have them put in a new clutch, throw-out bearing, pilot bearing, input shaft/bearings.
If I didn't have payments left on it I'd just scrap the damn thing.
