I am working on my mother in laws 2009 Patriot. Her power windows stopped working completely. I checked all the fuses which looked ok, even though none were marked as being for the power windows. I then took the door panel off and found the Pink/Brown wire that the wiring diagram lists as coming from the IGN SW OUT. It did not have 12V on it when measured with my meter. I created a small jumper wire and came off the power mirror switch and the windows started working. It makes me believe there is a short in the wire somewhere or maybe there is a relay that is bad.
Does anyone know if the power windows use a relay, and if so, where the relay is?
I have attached the wiring diagram I found on the internet.
