I will be giving my new Pat its first test tonight when I head into work. Shouldn't be too bad but I should have around 5 inches of powdery snow by the time I go in. I can't wait. I'm sure my Pat will do well.
IMO, you will have 0 problems. Ok, I guarentee you will be fine, your Patriot has you covered.I don't think I'll have any issues.
Nope! I was doing that at work late yesterday...LOLStupid question... ...am I the only person picturing Mrs. Klump clapping as she says the storm name?
Did you connect everything back up correctly?Well the Patriot was awesome in the snow last night and on the way home. I did however jump a coworkers battery and I must say that I disconnected the wrong part by accident. (Yes, I am kicking myself) The small sensor on top of the airbox. The engine cut out and I was able to start right back up but I now have a check engine light on. No loss in performance but the light is on. Any ideas?
Had to drive to Pittsburgh yesterday, left son in charge and last night as of 10pm we had 9" in Trumansburg. Had to leave pat home though.We got 1 to 1-1/2 feet as of this morning.
As I said it was an accident. Yes, everything is hooked back up correctly.Did you connect everything back up correctly?
Why did you take off the PCM to jump the other vehicle?
