21 - 34 of 34 Posts
i have the mopar wind deflector for the sunroof, yes it is leaking in from the rubber seal that is around the glass, but from the front end, I suspect the deflector mount is creating a mm gap, i stuck my finger there during a car wash and started feeling the wetnes and then the drips, when it leaks it leaks right on top of the roof liner which rivers into the dome light, so at the end dome light leaks like an open tap when all the water from a rainy day pools in...
couple of things to check:
Sunroof seal
Sunroof mechanism
glass warp
mopar air deflector defect
I keep u all posted
http://www.cagannyc.com
If I park upwards on a hill (hood up, hatch back) and it rains, i get water thru the rear dome light. If I park downwards on a hill or on level and it rains, i get water in the rear hatch. So I am basically screwed any time it rains!:mad:
Time to sign up with the law firm.
I dropped my Patriot off at the body shop last night to have some bodywork done, and when I was in the on-site Hertz location, there was a woman in there who was clearly peeved. The Hertz rep asked her what was being done to her car. She said she had just bought a Compass two months ago and there are a myriad of things wrong with it, including a sunroof leak... I wanted to chime in but I don't think that would have helped...
Dealer just called and said leak was from the sunroof and it is fixed now. They also replaced my radio since the lights of my radio was gone due to the leak... They also did a free oil change due to inconvenience... All under warranty! No charge! I am going to pick it up sat and test it in a car wash...
Hope they did a good job...
Sent from my Autoguide iPad app
Good luck, and let us know how it goes!
Hey guys, we have a 2009 Limited with the Sun and Sound package. After the first leak incident I asked the service manager about warranty. He said it was probably the drain lines clogged up and that is NOT covered under warranty. I was mad, but no problem (I can check that). Open sunroof and poured water near both front holes and down the metal rail that leads to the back holes (driver side and passenger side). Sure enough the passenger side front was not flowing. It was not that our sunroof was leaking, but that the water could not flow out. This caused water to come out front dome lights, front pillar, and back dome lights. I have had to clean the drain lines out several times, but when they are clean there is no water coming in the cab. When clogged, the water will get too high and go above the metal rail and run into the cab causing mine to look as if it was leaking, but really it can't get rid of the water fast enough when one of the four holes is blocked. I am not saying that some of these sunroofs are not leaking, but this has been our experience. I hope this may help someone keep their interior dry. I will never buy another Chrysler product with a sunroof. By the way, our third brake light leaks as well. Good luck staying dry in a Patriot:D
multi leak points
This year I purchased a 2010 Patriot that was a corporate vihicle with only 125 miles on it only to discover the dreaded roof leak! A trip to the dealer for checking and repairing the suspected sunroof drain hoses ended in continued leaking even though the dealer had proclaimed it "fixed".
I decided to take matters into my own hands and did some investigation with a garden hose and someone inside the car to spot for leaks. My first leak discovery was in the rear hatch area in the upper right hand side there was about a 1/4" hole where the seams had not been filled. I fixed that with some RTV. That took care of the rear leak. I discovered another leak with the sunroof, and, since the vehicle had it on already, and that I do not use it I took the "brute force" approach. I ran a small bead of RTV around the gap on the top of the sun roof. I then removed the fuse so no one could accidently try to open it. Several car washing and torrential downpours later, not a single drop inside!
I hope I dont go through this. I always wanted a jeep when I was a kid, and I finally bought one with sun and sound package, and I come from toyota and Nissan cars where I dont have problems like this. I traded an 11 Sentra SR special edition for my jeep, and I hope I dont have to regret it. We have had chrysler cars in the past and no problems, so I expect none from this one either.
I know this is an old thread but I called the law office on the first page today. They said their lawsuit is for vehicles 2009 or newer.... FYI
2008 or older they can do anything with because of the bankruptcy
21 - 34 of 34 Posts
