1 - 20 of 53 Posts
2011PatriotErie
I bought my 2011 Patriot on December 20, 2010, in large part because of the advertised gas mileage. The window sticker for my 2.4L, CVTII, 4WD is 21 mpg city and 26 mpg highway. Thus far, while driving in very light city conditions and then on a highway trip to Pittsburgh (from Erie, PA), I have been getting 17-18 mpg and 21-22 mpg, respectively. That is far below the advertised mileage, and that's with only a couple miles of 4WD driving time, and I do not let the vehicle sit idling at ATMs nor do I let it idle a long to warm up (kept in a partially heated garage). On my last vehicle (2007 Cobalt) I routinely beat the sticker mpg by 5-7 mpg, so my driving habits are not at fault.
When I called the dealer's service department (Gary Miller Chrysler-Jeep. Erie, PA), I was told it's because of winter fuel mixture, the engine not being broken in yet, and even that the fan motor from the heater are the cause. The guy was serious about the fan motor on the heater. The EPA is very stringent about the conditions under which mileage ratings are published, so I don't buy the line. Modern engines are built to very close tolerances and require almost no break-in period. The winter fuel blend might be responsible for a little of the bad mileage, but this is 20% below advertised. It's at the very bottom of the range that factors in worst-case conditions like full load of passengers and cargo, hilly terrain, windows down, etc. My conditions are about as close to ideal as possible.
With gas heading for $4 per gallon, this is very distressing. I specifically chose the Patriot over the Ford Escape because of the gas mileage. My 4-cylinder Patriot is getting the gas mileage of the 6-cylinder Escape - totally unacceptable. BTW, mileage calculations are via the Vehicle Information Center (VIC) computer that I ordered with it, so the values are not subject to filling at the same gas pump each time, tracking miles accurately, etc; the VIC calculates the values real-time, and I monitor them closely.
For the first-ever Chrysler product in my 52 years, I'm not impressed.
Most of us on here had horrible gas mileage until we got a good couple thousand miles on the engine. I myself only saw 18mpg when new, but after about 3000 miles, I was getting 22-23 mpg around town (mine was rated at 21mpg City). Now some of that may be from break-in, some from the computer "learning" your driving habits, and some from learning how to drive a CVT equipped car, but don't despair just yet. The mileage will get better. Also these engines love heat, so while it may not be the heater blower fan directly, it is pulling coolant temp out of the engine.
I have a scangauge II hooked up on my Patriot, and in the winter I've seen the coolant temp stay at a steady 172 deg F. Some members have made up radiator blockers to get more heat into the motor, and thus also increase fuel economy. Myself, I remove the battery cover/fresh air duct which makes the engine breath the heated air under the hood. It helps offset the winter fuel mix, which will drop your fuel economy 1 or 2 miles per gallon.
Oh and don't rely on the EVIC just yet. Do the actual calculations on miles driven vs. gallons of gas pumped in. I'm pretty sure the EVIC only does average MPG and it may need to be reset or something. Especially if one of the dealer lot hounds hot footed around in the thing prior to you buying it.
Low mileage, cold temperatures, and winter mix fuel... all are going against you.
Hang tight till this summer and see what you can get.
IMHO, the perfect conditions for the Patriot are about 70°F, summer gas, 50-60mph speeds max. With those, I routinely beat the sticker rating by 2-3mpg.
Thanks for the response, guys. I did reset the EVIC to zero out everything. I'm just shocked at the cruddy mileage when I bought it specifically for good gas mileage. I sold my Ford Explorer three years ago because it got only a little worse mileage as what I'm getting now with this Jeep.
Mmmm...obviously, is too new to get good mpg, any brand any car.
2nd, I noticed: the way that you normally drive, is a little bit different in the patriot. When I bought the pat, I got the same mpg than my Liberty 3.7 v6... but I learned to drive this jeep, and now I really love the mpgs. I own a charger, 5.7 hemi right now, but a couple of years ago, I owned at the same time the SXT with 3.5 v6, and guess what?? I got better mpg with the Hemi.
So, the weather conditions, how you drive, size, weight...manual, auto, CVT or autostick can get better or worse mpg.
You guys mention learning how to drive the CVT. I'm pretty new to the forum. How about enlightening the newbs with what you mean?
Check my Fuelly numbers for the first two tanks-horrible!!! Now here is a question? I've been getting 10.5 / 10.6 L/100km during the winter and then I did the computer reset and I got 9.7-huhh???? Next tank it went right back up. I reset it again and I'll wait to see what I get this time.
I have 25000 miles on my Pat and mileage never increased.. With the slightly bigger 215/65/17 tires it has actually dropped to 20 city 23 highway. With the 215/60/17 tires i got between 21-22 city and between 25-26 highway.
driving the cvt
As you may have learned yourself the cvt seems to really suck some power from the engine especialy in acceleration and passing vehicles. i think they mean watching your rpms, to increase fuel mileage and acceleration because of the tip-tronic option (Manually shift able automatic). the lower your rpms on the free/high way can increase your mileage dramatically. also when you use the manual option you can granny (drive at low rpms on straight aways and really get good acceleration by learning rpms.
this is just what i thought they meant i could be wrong. hope this helps.
I hope you guys are right about the engine just being new and the gas being a winter blend. My low fuel light came on today and the trip odometer indicated a total of 183 miles driven! I haven't filled the tank yet, but depending on how low the tank really is it could come out to 15-18 mpg. Granted, it was all city driving, but come on! My 99 Cherokee I replaced got the same mileage. Here's to hope.
I´m pretty sure, your engine is to new. Or you have a heavy foot!! LOL ;) just kiding.
I got 24 mpg CITY, driving very slow...well, not to slow. I try to keep my tach in 1,500 rpms always in city, to get 24 or 24.5 mpgs. If you feel something wrong, ask the dealer :D
regards and good luck!
I bought my 2011 Patriot Sport 4x4 FDI CVTII on Sunday 1/16/11. I went over 200 miles to a dealership to get mine. On the way home I went 176 miles on the interstate at 70 to 80 MPH then another 56 miles on 2 lane roads for a total of 232 miles. I filled up before I got home to start the week off with a full tank. I was able to put in exactly 10 gallons so 23 MPG on first tank. I have a long commute everyday and so far I have around 220+ miles on the second tank of gas and still have a little over a 1/4 of a tank.
I have the 4x2 with 2.0 and CVT II. I've been getting around 23. My commute is aproximate a mile or so of city driving with 6 traffic lights, then around 13 miles of highway at 70-75 mph, then 6-7 miles of 60 mph highway, then another 5 miles or so of city driving with another 7 traffic lights.
That said, mine just tipped 1000 on the odometer. I noticed this morning that I've gone 160 miles and still have a half tank of fuel so I'm thinking my mileage is going to be a little better this time.
2011 Patriot Sport 4x4 FD1 with CVT11
Just filled up my second tank full. I drive 80 miles a day.
70 miles on 2 lane roads and 10 on four lane.
Had 301.4 on that tank and filled up with 11.50 gallons
26 MPG compared to my TJ with 6''lift on 35's
:pepper:
WHOOP WHOOP
2011 Patriot Mileage
Just came home from a 600plus mile trip - mostly highway driving. 1650 miles total on the Jeep so far.
Fuelly tracking is looking good....
2.4, 4x4 CVT.
Basically I let the auto shift do its thing for the most part and keep the RPM's under 2-3k when possible. Basically 55-60 mph on the highways. No jack rabbit starts. I came from a 2007 Pontiac Grand Prix GXP V-8, yeah it could do 0-60 in under 6 seconds, BUT it cost ya....got about 14-17 average in that puppy.
I will take the 25 mpg average of the Jeep ;)
Oh yeah, took the Patriot to OBX - spent a day out on the northern 4x4 beach - it was rough, but the Patriot did OK... kept up with many of the big boys, several people stopped to ask how it got out there! The fully running average includes the day driving on the beach in 4x4 locked mode in low gear, high RPM to keep the torque up, so I am really happy!
2011 Latitude X, FDII
5300 miles
21 fill ups recorded
Combined AVG = 22.93
Best tank avg = 25.48
Worst tank avg = 21.39
I bought my 2011 Jeep Patriot Latitude 70th Anniversary Edition 4 x 4 1 week ago and I have 1300 miles on it and I am averaging 25.6 miles per gallon. I am very happy with this
I got a 2011 Latitiude 2.4L CVT 4WD FDI in August. My Fuelly average is 23.6 MPG but it doesn't have the last fill as part of it( can't recall exactly what I got but it was low 23's again as memory serves ). I have about 1300 miles on the vehicle now.
Worst tank = 21.4( a good 50% + of the tank was towing my boat )
Best tank = 29.7( 90% highway run in CC @ 60 MPH )
Winter gas is here now as are colder temps so I expect to lose anywhere from 1-2 MPG until next spring. I DETEST winter gas. It absolutely KILLED my MPG when I had my 5.3L Silverado's and HEMI Ram's.
1 - 20 of 53 Posts
