Bigger Radius Tires vs MPG Gains
Any vehicle on which a larger radius, larger circumference, larger diameter (all diff ways to say same thing), is installed the odometer will produce less numbers. That's because the larger tire rotates less number of times per mile.
Sure, we can argue various points: more torque required (although not much more), larger radius tire generally wider causes more wind resistance (although not by much), larger radius tire weighs more (although not by much), etc.
The bottom line is that the mechanics of the components driving the odometer, trip meter will turn less per mile. Even with a super powerful motor that will over come added wind resistance, torque problem, added weight - the same is true - less turns of tires to tick up the odometer.
So, every one of you who ignore this fact in your calculations will compute inaccurately.
A GPS is the only way to truly know how many mile you drove in a test drive after new larger tire installation. Also, the other difference factors, weight, wind resistance, torque - require a vehicle to be driven several thousand miles IGNORING THE ODOMETER and focusing on only a GPS mileage number to calculate the actual mileage accurately.
All we have to do is accentuate, exaggerate tire circumference (or radius or diameter) size to demonstrate my point - more tire circumference, radius, diameter is less odometer. You car isn't lying to you, just confused - unless it has a way to punch in the tire size and it can adjust its computations.
Put a set of tires on a vehicle that is 20 feet of circumference - 20 ft around the tire. This will cut down on odometer reported mileage every time big time. Fuel efficiency will differ between vehicles. This is of course an exaggeration. If we increase tire diameter by 3 inches then we must travel a good number of miles to realize the drop in odometer readings.
But, suppose you up-size the tires on your vehicle without decreasing fuel consumption for 500 GPS confirmed miles. The odometer, trip meter will show less miles. So please ignore the odometer and on-board computer for computations of accuracy and recognise that bigger tires produce less revolutions per mile yielding less miles at the odometer.
He who has no GPS, and uses the odometer for mileage readings after up-sizing tire circumference size to compute is lying to themselves.
