I wouldn't be so quick to blame the system. Maybe yours isn't working right. As for me, I think in highway snow -- not glare ice, I realize, but in highway snow -- where I might want to be driving 40ishMPH, my FWD Patriot is better, yes better, than our Wrangler. The Wrangler is great in deep snow and nothing beats it off road, but on a snowcovered expressway the fat tires and relatively square stance means the Wrangler gets sideways rather easily. Not so with my Patriot.
Absolutely, In highway snow, no problem-Great traction and stability. It is great.
You also state that you have the front wheel drive model...... big difference than the AWD model with ETC, ECC Etc. The engagement timing of these devices has to be perfectly tuned together to work with the ESC on Glare ice roads. I truly believe that your front drive Patriot handles better than your Wrangler under slippery road conditions. No doubt about it.
But...... In all of the posts on the internet regarding fishtailing Patriots I have never seen anyone come up with the cure or a system to analyze the inter workings of the various sensors.
Does one start with the throttle position sensor, then the ECC module adjustment or what?
It seems to be a real money maker for the dealership. What is the procedure for making one of these run right?
Nobody seems to have the answer. Or the procedure.....Except installing the traction dial selector on the newer models. Which i do not believe is an option for a 2014 model and earlier model.
Like I said earlier. Our 305 mile trip took 8 hours and sixteen minutes to travel (only during time was counted.). We were passed by every vehicle headed west on Hwy 8, 51, 29 and 94. We did manage to pass one plow truck who was doing 30 mph and that was it. We averaged 37 MPH overall. Cars in the ditch, a 350, an Explorer and one semi.. We could not keep up with anybody and they were not traveling at unreasonable speeds. So......
If you have the correct diagnostic procedure to correct this unacceptable situation , please lay it out and share it with us.
