61 - 80 of 98 Posts
Rubles
the info posted by Milous (and later Canada info, posted by myself) is essentially complete, just remember that the 4x2 North Edition is the "E" trim level. Do you have a specific question that we might be able to dig up?
Thanks Milous but what about the specs of the Patriot North Edition (Canada)?
Pierre
If post #49 not enough let me know or PM me with a question.
Dave
Canadian 4x2 MSRP pricing - some have asked
CA 2010 Jeep Patriot 4dr Front-wheel Drive Sport/North
Model Code: MKTL74
Fuel Economy: City: 9.7 Hwy: 8
Description MSRP
Base Price $17,595.00
Freight $1,400.00
Selected Options $6,000.00
Total Vehicle Price $25,095.00 *
* includes $100 Canadian Air Tax.
Type Code Description MSRP
26E Quick Order Package 26E $3000
JKV 115V Auxiliary Power Outlet
HAA Air Conditioning
GEG Deep Tint Sunscreen Glass
CDH Driver Seat Height Adjuster
CDW Front Passenger Forward Fold Flat Seat
GXR Keyless Entry
LAC Illuminated Entry
MT5 North Badge
GTL Power Heated Fold-Away Mirrors
JPD Power Driver 1-Touch Windows
JPH Speed Sensitive Power Locks
MNK Body Colour Door Handles
MPN Body Colour Liftgate Applique
K6 Stain Repel Cloth Bucket Seats
XGW Stain Repel Seat Fabric
ACF Tire & Wheel Group $600
WFJ Wheels: 17" x 6.5" Aluminum
TRX Tires: P215/65R17 OWL All Terrain
AJB Security and Cargo Convenience Group $1000
MWF Adjustable Roof Rail Crossbars
CMA Heated Front Seats
GNK Rear View Auto Dim Mirror
XBM Remote Start System
LSA Security Alarm
CSU Soft Tonneau Cover
CJ1 Supplemental Front Seat Side Air Bags
XGM Tire Pressure Monitoring Display
XGD Universal Garage Door Opener
LAZ Vehicle Information Centre
DAV Transmission: Continuously Variable Transaxle II $1400
NONAX 6.12 Axle Ratio
DHD Autostick (R) Automatic Transmission
XBN Tip Start
ED3 Engine: 2.4L 4 Cylinder DOHC 16V Dual VVT STD
RES Radio: Media Centre 130 CD/MP3 STD
Z1A GVWR: 2,012 kgs (4,435 lbs) STD
________________________________________
Standard Equipment Powertrain
Engine--2.4L (144.0 cu.in.) I-4 DOHC SMPI 16 valve engine
Ignition Type--Electronic ignition
Engine Location & Orientation--Transverse engine
Engine Head & Block--Aluminum engine block & head
Engine Cylinders--I-4
Variable Valve Timing--Variable valve control
Variable Intake Manifold--Variable intake length
recommended fuel--Regular unleaded
Alternator--120 amp alternator
Battery--525 CCA 60 amp hours (Ah) battery with run down protection
Engine Block Heater--Engine block heater
Transmission--5-speed manual transmission with overdrive
Drive--Front-wheel drive
Traction Control--ABS and driveline traction control
Axle Ratio--4.12 axle ratio
Exhaust--Stainless steel exhaust
Emission Type--ULEV II emissions
Steering and Suspension
 Steering--Hydraulic power-assist rack and pinion steering
 Brakes--Front disc/rear drum brakes with front vented discs
 Brake Assist--Brake assistance
 Electronic Stability--Stability control
 Suspension--Touring ride suspension
 Front Suspension Independence--Front independent suspension
 Front Suspension Type--Front strut suspension
 Front Anti-Roll Bars--Front anti-roll bar
 Front Springs--Front coil springs
 Front Shocks--Gas-pressurized front shocks
 Rear Suspension Independence--Rear independent suspension
 Rear Suspension Type--Rear multi-link suspension
 Rear Anti-Roll Bar--Rear anti-roll bar
 Rear Springs--Rear coil springs
 Rear Shocks--Gas-pressurized rear shocks
 Wheels--Front and rear 16.0mm x 6.50mm silver styled steel wheels
 Tires--P205/70TR16.0 BSW AS front and rear tires
 Spare Tire--Inside under cargo mounted compact spare tire
 Spare Wheel--Steel spare wheel
Safety
 ABS--Rear wheel anti-lock braking system with 1 ABS channel
 Safety Lights--Daytime running lights, centre high mounted stop light
 Front Airbags--Dual airbags
 Overhead Airbag--Curtain 1st and 2nd row overhead airbags
 Airbag Occupancy Sensor--Airbag occupancy sensor
 Seatbelts--Front height adjustable seatbelts with 2 front pre-tensioners, rear centre 3 point
 Ignition Disable--Sentry Key ignition disable security
Comfort and Convenience Features
 Steering Wheel--Steering wheel with tilt adjustment
 Rear Windows--Manual rearmost windows
 Tinted Windows--Light tinted windows
 Windshield--Variable intermittent front windshield wipers
 Rear Windshield--Fixed interval rear wiper
 Rear Defroster--Rear window defroster
 Interior Mirrors--Dual vanity mirrors
 Rearview Mirror--Day-night rearview mirror
 Dome Light--Dome light with fade
 Reading Lights--Front reading lights
 Variable IP Lighting--Variable IP lighting
 Floor Console--Full floor console with covered storage
 Glove Box--Glove box
 Cupholders--Front and rear cupholders
 Dashboard Storage--Dashboard storage
 Door Bins--Driver and passenger door bins
 Rear Door Bins--Rear door bins
 Audio Media Storage--Audio media storage
 Cargo Space Trim--Carpeted cargo floor, plastic trunk lid/rear cargo door
 Cargo Tie Downs--Cargo tie downs
 Cargo Light--Cargo light
 Air Filter--Air filter
 Underseat Ducts--Underseat ducts
 Radio--AM/FM/Satellite-capable, clock, seek-scan, with in-dash CD, MP3 decoder, radio data system
 Speakers--4 speakers
 Antenna--Fixed antenna
 Rear Child Safety Locks--Child safety rear door locks
 Driver Foot Rest--Driver's foot rest
 Retained Accessory Power--Retained accessory power
 12V DC Power Accessory Outlet--1 12V DC power outlet
 Instrumentation--Analog instrumentation display
 Tachometer--Tachometer
 Water Temp Gauge--Water temperature gauge
 Exterior Temp--Exterior temperature gauge
 Trip Odometer--Trip odometer
 Oil Pressure Warning--Oil pressure warning
 Water Temp Warning--Water temperature warning
 Battery Warning--Battery warning
 Lights On Warning--Lights on warning
 Key in Ignition Warning--Key warning
 Low Fuel Warning--Low fuel warning
 Door Ajar Warning--Door ajar warning
 Trunk Ajar Warning--Trunk/liftgate ajar warning
 Brake Fluid Warning--Brake fluid warning
 Low Tire Pressure Warning--Low tire pressure warning
Seating and Interior
 Seating Capacity--Capacity of 5
 Front Seats--Bucket front seats
 Front Head restraints--Adjustable anti-whiplash front head restraints
 Front Armrest--Centre front armrest with storage
 Driver's Seat--4-way adjustable driver seat with manual reclining, manual fore/aft
 Passenger's Seat--4-way adjustable passenger seat with manual reclining, manual fore/aft
 Rear Seats--60-40 folding rear fold forward seatback bench seats
 Rear Head restraints--2 fixed rear head restraints
 Front Seat Trim--Vinyl faced front seats with plastic side and back
 Rear Seat Trim--Vinyl faced rear seats with carpet side and back
 Headliner--Full cloth headliner
 Floor Trim--Full carpet floor covering
 Gear Shift Knob Trim--Chrome gear shift knob
 Floor Mats--Carpeted floor mats
 Console Insert--Chrome console insert
 Interior Accents--Chrome and metal-look interior accents
Exterior Features
 Side Impact Bars--Side impact bars
 Body Material--Fully galvanized steel body material
 Window Mouldings--Black side window mouldings
 Front Windshield Mouldings--Black front windshield moulding
 Door Handles--Black door handles
 Grille--Body-coloured grille
 Door Count--4 doors
 Rear Cargo Door--Liftgate rear cargo door
 Roof Features--Side rails only
 Exterior Mirrors--Dual manual black folding outside mirrors
 Mirror Style--Regular style mirrors
 Bumpers--Front and rear body-coloured bumpers
 Rear Step Bumper--Rear step bumper
 Exterior Lights--Aero-composite halogen headlamps
 Paint--Clearcoat monotone paint
Warranty
 Basic--36 month/60,000 km
 Powertrain--60 month/100,000 km
 Corrosion Perforation--60 month/160,000 km
 Roadside Assistance--60 month/100,000 km
Dimensions and Capacities
 output--172 hp@6,000 rpm
 torque--165 lb.-ft.@4,400 rpm
 bore x stroke & compression ratio--88mm bore x 97mm stroke with a 10.50:1 compression ratio
 1st gear ratio--3.770
 2nd gear ratio--2.160
 3rd gear ratio--1.410
 4th gear ratio--1.026
 5th gear ratio--.810
 reverse gear ratio--3.417
 city/hwy--26/33
 curb weight--1,410 kg
 GVWR--2,012kg
 payload--420kg
 towing capacity--454 kg
 front legroom--1,031mm
 rear legroom--1,001mm
 front headroom--1,041mm
 rear headroom--1,013mm
 front hiproom--1,328mm
 rear hiproom--1,295mm
 front shoulder room--1,387mm
 rear shoulder room--1,372mm
 passenger area volume--2,880 L
 length--4,409mm
 body width--1,755mm
 body height--1,636mm
 wheelbase--2,634.0mm
 front tread--1,519.0mm
 rear tread--1,519.0mm
 turning radius--5.43m
 fuel tank--51.0 L
 interior cargo volume--651L
 interior cargo volume seats folded--1,535L
 interior maximum cargo volume--1,776L
 interior cargo height--658mm
 interior cargo minimum width--965mm
 interior cargo maximum width--1,146mm
 approach angle--28.1 deg
 departure angle--32.2 deg
 ramp breakover angle--21.3 deg
 min ground clearance--203mm
 load floor height--775mm
Available Options (Equipment Not Selected)
24D Quick Order Package 24D $0.00
24E Quick Order Package 24E $3000.00
25D Quick Order Package 25D $0.00
25E Quick Order Package 25E $3000.00
26D Quick Order Package 26D $0.00
2BD Quick Order Package 2BD $0.00
2BE Quick Order Package 2BE $3000.00
AEY SIRIUS Satellite Radio Group Variable
AGS Sun/Sound Group $1250.00
AMA Premium Sound Group $575.00
AWS Smoker's Group $75.00
B7 Cloth Low-Back Bucket Seats $175.00
CDL Manual Driver Lumbar Adjust (Fleet) $50.00
CSU Soft Tonneau Cover (Fleet) $100.00
ECN Engine: 2.0L 4 Cylinder DOHC 16V Dual VVT $0.00
GWG Power Express Open/Close Sunroof $1100.00
NHM Speed Control $275.00
REQ Radio: Media Centre 230 6CD/DVD/MP3 $475.00
RSC SIRIUS Satellite Radio $275.00
TBB Full Size Spare Tire $200.00
Vehicle Specifications are subject to change without notice. The actual Manufacturers' Invoice for factory orders will be used as the basis for final vehicle
Thank you ..............
Dave and Milous for the excellent info and pics.
On checking my sales contract order date June 26 so hopefully I'll get my hands on it early October:smiley_thumbs_up:
I'm not sure if it's the long lead time or because it's my first JEEP (I don't normally get excited about vehicles) because I'm really looking forward to to its arrival. This is the first time I've looked at after market add on products. The first thing I plan is to find those light reflective decals (for fun) and the body/door side moldings (practicality) and maybe a licence plate frame "It's a Jeep, you wouldn't understand" (for fun). And I never thought I'd be driving Inferno Red anything:pepper:
search ebay under "jeep patriot bumper insert"
But be sure to order your jeeppatriot.com decal:smiley_thumbs_up: as your first aftermarket accessory
secondly, paint muffler (I used high heat bbq paint)
thirdly, ......
It's a Jeep thing
Found this on an edmunds blog
Tip Start is part of the electronics that cranks the engine over until it gets a signal to the computer that the engine has started. This was done so that people will not crank over a started engine,or that you cannot engage the starter too long. This was done for warranty purposes. It may be possible for the dealer to de-activate the Tip Start feature but you will have to ask them about it
Pierre
Dave
The presentation of the Sport and North Edition are the same :
Same base, same options. So what is typical of the North Edition just the name and badge? There should be a package linked to that model in my opinion. If not, a base Sport model could have the same options as a North Edition model without being a North Edition specifically. :confused: :BLAM:
Here is a sport with no options but yes the software groups them together
Model Code: MKTL74
PATRIOT SPORT
Description MSRP
Freight $1,400.00
Selected Options $1,125.00
Total Vehicle Price $20,220.00 *
* Total Price includes $100 Canadian Air Tax.
2BD Quick Order Package 2BD N/C
APA Monotone Paint Application STD
DD7 Transmission: 5-Speed Manual T355 STD
E6 Front Vinyl Tech Bucket Seats STD
ECN Engine: 2.0L 4 Cylinder DOHC 16V Dual VVT N/C
HAA Air Conditioning $1,125.00
STDAX 4.12 Axle Ratio STD
TLB Tires: P205/70R16 BSW AS STD
WDJ Wheels: 16" x 6.5" Styled Steel STD
Standard Equipment
Power and Performance
Engine--2.4L I-4 16 valve DOHC SMPI
Drive Type--Front-wheel drive
Transmission--5-spd manual w/overdrive
Active and Passive Safety
Lights--Centre high mounted stop light
Braking System--Rear wheel anti-lock brakes (ABS)
Ignition Security--Sentry Key ignition disable
Radio--In-dash mounted single CD player
Instrumentation--Trip odometer
Warning Indicators--Engine temperature
Warning Indicators--Battery warning
Warning Indicators--Door ajar warning
Warning Indicators--Brake fluid warning
Steering Wheel--Tilt steering
Ventanas--Light tinted windows
26E Quick Order Package 26E $3000.00
ACF Tire & Wheel Group $600.00
AJB Security and Cargo Convenience Group Variable
CJ1 Supplemental Front Seat Side Air Bags $400.00
DAV Transmission: Continuously Variable Transaxle II $1400.00
K6 Stain Repel Cloth Bucket Seats $0.00
NONAX 6.12 Axle Ratio $0.00
TRX Tires: P215/65R17 OWL All Terrain $0.00
WFJ Wheels: 17" x 6.5" Aluminum $0.00
Continuously Variable Transaxle w/Off-Road Crawl Ratio - $1,050
Automatic variable-speed transmission with manual mode and low/high gear ranges DAW and continuously trans with manual mode; Drive speed limited (manual only) and crawl control; Requires: [AWL] Freedom Drive II Off-Road Group; Excludes: [DAV] Continuously Variable Transaxle II
This means what I think it does? Has autostick been added to FDII? This might eliminate the stalls people have talked about when going up steep hills.
100% for certain the new OM651 diesel will be offered in the 2010 Patriot export models...
From a post I made in May of 2008:
"In the 2010 model year (Patriot) export models will get an all-new diesel..." (http://www.jeeppatriot.com/forum/showpost.php?p=72228&postcount=16)
It is 2.2l Mercedes Common rail diesel (real not rebagged TDi) and will have 163hp and 320Nm of torque. I believe that new 6speed gearbox will be as well with longer 6th gear for lower rpms and better economy!
Hmm, that's interesting .............
US Fleet Warranty Information
* Basic--36 month/36,000 miles
* Powertrain--Unlimited month/unlimited mileage
* Corrosion Perforation--60 month/100,000 miles
* Roadside Assistance--36 month/36,000 miles
no sign of a brochure yet
When I ordered my 2009 Pat the 100,000 powertrain warranty was included.
So I wonder which warranty will be honoured?
website update not likely until first or second week of October
Powertrain warranty has always been different Canada and state side.
(PGJ) Jeep Green final build 8/14/09*
NATURAL GREEN PEARL COAT (Late availability)
IOW anyone wanting a green Patriot is out of luck for the next year?
Is it any wonder that Chrysler is having problems when the people in charge make stupid decisions like this?
61 - 80 of 98 Posts
