A few months ago, I rotated tires, and now within the past few weeks the one on the passenger right is wearing incredibly fast. Just in the past 100 miles or so the tread dropped 1/32.
The wear is in the central tread, which would normally indicate PSI is too high. I've checked all tires several times and they're all at 35psi.
Would this be a sign of impending tire failure? Any suspension issues would cause other wear, correct? I've worked many years in past in the tire business, but have never seen accelerated center wear on a tire with correct psi.
I'm going to have to replace the tires soon anyways, since it's below safety spec, but need to know if it's possible any other condition could cause this before dumping money on new rubber. Thanks guys!
