1 - 7 of 7 Posts
STOCKYbuilt
Stuck... not for long though, but...
...at the position it sat while this pic was taken, my Pat was "stuck". I've put in 4WD LOCK, and Full ESP OFF (which I got fixed), and put in Reverse...
Results: Driver's side Front Wheel spun. I did not feel the rear wheels nor the front passenger side's activate at all. How I knew, is that this tiny "snowbank" wasn't high at all, and there was not enough snow to really get stuck in. Almost every other wheel pretty much had traction. The front driver's side spun til it dug into an ice patch/dirt... even after I've straightened out the wheel.
I had to pull the Jeep forward and back right out with a lil bit of momentum (in 4WD).
Is this normal? I know it's nothing like a Lock Differential ...but how (and when) does it think to "send torque" to the other wheels with traction?? I had no witnesses from the outside to view the action... but I was quite sure the other wheels were asleep at that moment...
That said, I still love this frickin thing... :) Afterall, it's the Little Jeep (or Car) that Could...
Does the Patriot have 4WD in reverse? My XJ does not, but it doesn't have the same system as the Patriot.
Well had a big dump of snow yesterday, and tried 4x4 LOCK again (but in leveled ground this time without articulating), the rear wheels worked... I could feel it. I even opened the door to peek at one of them spinning in reverse. So, at the moment, I'm convinced the centre diff lock is working - just probably not the best in response under certain situations.
Perhaps it sometimes take a little while for it to think before actually sending the power to the other wheels?
I have noticed that in similar 3-wheel teetering situations that the center clutch is not engaged very much in normal AWD mode. Pulling the t-handle made a significant difference.
Hoosiermud, the XJ transfer case is mechanical and does have 4WD (both high and low) in reverse.
1 - 7 of 7 Posts
