Wood grain dash kit.
24K views 57 replies 28 participants last post by  tiptronic
Here are photos of my Pat's interior, with the wood-grain kit installed. Takes care of the "cheap plastic" look. Now it looks like expensive plastic.
You can see my iPod gadget as well. It's a Griffon Road Trip FM transmitter, and it works very well around here, where there's no FM station near 106.9 on the dial. Don't think it would work in TO, NY, or LA.
On the door interior shot, you can see two answers to the rock-hard arm rests. I made the black one from foam rubber and leatherette wrapped around some cardboard and held down with velcro. It's okay, but not high enough. I bought the beige one from CarTruckToys.com. Don't like it much. It doesn't fit very well, and it's much too small... smaller than it looks in the ads. I'm going to try to make a better one, and replace both of these efforts.
Here's a link to the Wood Grain kit people:
http://www.wooddashexperts.com/customer/home.php?cat=5341
By the way, there are many colours available. Mine is the Cherry Wood because it seemed to go best with the beige interior.
I shot a bunch more photos in the last day or so. I'll post them shortly.
There is no need to get sarcastic Jeepkid- Some of us think that it looks much better than the original.
Yooo I wasnt being sarcastic. I IS indeed better...Isnt it? You said it is better, why cant I?
But while im here, My actual opinion about it is that:
Cars that DO come with wood grain interior dont come with THAT much. Things look very "home-made" when it is over done.
Over all...I like it.
I had a look at their site. I think the real wood kits look pretty cool if you don't go overkill on them. I did notice their is an extra cutout on the main center panel under the heat and air controls that the '08s dont have (at least mine doesn't) so until they fix that I guess I'll have time to mull it over and see if I really want to do it. Probably a good thing since I am a complete impulse buyer!
Jeepkid: There are several companies who make theses kits. Some come with more pieces than others, and I agree. It can be overdone. Most sellers have a basic kit and a more expensive kit with more pieces. So it's possible to avoid overdoing it, and saving some money, as well.
Gagemaster: They're easy to install, but you should set aside an afternoon for it. The pieces have an adhesive, and come to you stuck down to a plastic release sheet. They should be applied in warm weather, or, I warmed up the interior with an electric heater, and also had a hair dryer and a small wallpaper roller on hand.
I heated up the dash panel with the hair drier, then carefully lifted off the wood grain (which is thick, but flexible). The trick is to position it very carefully before applying any pressure, because the adhesive is extremely sticky. If it isn't pushed down, you can reposition it until you get it right. Then rub it down (I used the wallpaper roller).
I only had one problem. I installed one nearly-square piece turned 90 degrees. Didn't realize the error until it was stuck down. Finally managed to get it off by heating with the hair drier, and peeling carefully.
The one thing I worry about is the edges.
I have seen some kits labeled 'molded' that have wrap around edges, but none for the Patriot.
How noticeable is the silver sandwiched underneath the application?
The one thing I worry about is the edges...
I second that. I think overall it is a big improvement, but I don't care for the silver/argent peeking out at the edges. I think I'd prefer to remove the trim pieces, paint them myself with a faux wood finish (it's not that hard to do), and apply a semi-gloss clear coat on top (not too shiny), and then re-install them. I wouldn't have to worry about the edges, and it would be a whole lot cheaper!
#19 · (Edited)
It would be nice to have one of the 3-D ones you're referring to. However, my kit was made of very thick pieces, not like wallpaper, so it looks like a slab of highly polished wood. In fact, some are made of real wood. In some places you can see the edges from underneath, in others you can't. But I think this one looks better than the factory wood-grain on my old Mercury Sable.
This company can also make custom kits if you send them a pattern. So I'm thinking of getting some pieces made for my old Studebaker. It's 44 year old "wood-grain" is getting faded.
I was thinking of painting also, but only the silver that is peeking out. Something close to match the new trim.
I have the REC unit and Neil's supplier is the only one I can find with the proper cut out.
Which is fine because if I was going to do it I think I might splurge and go real wood.
As Kramer says... "It's like a Ski Lodge in there.. Wood.. Jerry.... WOOD!"
I would like something right in between the kits offered.
The basic kit doesn't have quite enough and the full kit has more than I would put on.
You must have gotten the full kit Neil? And just didn't install all the pieces ... or.....?
That's right. There were bits for the back seat area, speaker areas, which I thought was too much.
Jim, try my suggestion and Google "wood-grain dash kits". I found three or four other manufacturers, each with their own ideas.
